Lets see all them Amplifiers!
OK, this should be amusing.
I just moved one of my Traynor amps up into my home office so that I have something to use there, too. To keep the levels down, I swapped in those GT adapters that let me run EL84s instead of EL34s. So, here is the amp, an old YBA-1, next to a little speaker I made using a $4 Nippon America driver I got from electronix.com. It's a 5" midrange driver rated at 25W, so it may survive the output from the EL84s... we shall see.
Here is my Korg PME pedal board with the modules I have in at the moment. I think I have a total of 15 modules and I have three of the base units. The other funny looking thing is no longer a sustain pedal made from a PAiA kit, it is just an A-B switch box I made so that I can easily switch inputs on the Traynor amps, which don't have built in switching between inputs. BTW, the masking tape on the cord is not remedial, it was a label.
Finally, here is my most played guitar, a '62 Gibson Melody Maker with two pickups. I got it from Mitch Easter in a trade for a 3M M-23 tape machine. Yes, that's a Schaller tailpiece, so I can get it to play in tune in one of several tunings.
Otto
oooh buddy... you're asking A LOT of that little guy! Let us know how it works out!
Well, I played some yesterday, even with gain turned up a bit, perhaps to 7 or so and it was quite fun and sounded pretty good other than a bit weak in the low end, as you would expect. No damage so far.
If I could run a single EL84 amp in the office, I would, but would that involve spending money.
That pair of EL84s would be rated about 15 watts or so, though we all know that tube amps like this can put out a lot of signal, with big peaks and sometimes more than what the rating might indicate.
Plus, some of us might tend to turn the volume up high to get the output tubes to distort and the cone to start to break up. :yes:
Otto
Nice Traynor and effects rig!
Very cool Melody Maker!
Mines a '68 with an SG style body and two pick ups....
Thanks! I also have an old YSR-1 that sees a lot of use. It has only bass and treble, so even I would be hard pressed to get a bad sound out of it.
I really like the Melody Maker. It sounds great, plays great and it's not heavy. The pickups are super noisy, but they sound incredible.
I've been a big fan of the Korg PME effects since they came out in the early 1980s. I've used them on synths, bass, guitar, Stick, even vocals at times.
Otto
Actually, I've moved all guitar, amp and related goodies back to the studio, which I tidied up a bit, so that there is more room to romp. Both amps are paired up with 1x12 cabinets that are a good match for the amps. It's a much better place to make noise. :music:
Otto
I had one of my amps apart today to clean the pots. Still sounds really nice when all the gunk is blown out! It's a '67 Twin Reverb.
45 year old ceramic disk caps... how long can possibly they last?? :eek:
Original Jensens still chugging away.
SN A11111.... :scratch2:
It pretty much looked like this when I bought it in '90... heavily 'pre owned'.
With ESP 400
Another favorite, Marshall 1986 50w Plexi reissue. Not sure of the year, early 2000s. Sadly, I parked it a few years ago when it started blowing fuses, need to get it looked at.
This is a great thread, there's some really nice stuff here - eez makes me jealous! I've always wanted a Deluxe Reverb, I'd be fine with a reissue... but no I must get what I have up to scratch first. Sigh.
Does this qualify
Here is my guitar amp
My Gyrophonic projector speaker, with two 8" speakers that rotate vertically, coupled with my Roberts 990 converted amp. The tube rectified, SET amp puts out 4 or possible more EL84 watts and I use a 12ax7 in the pre-amp stage.
You gotta know how to run the Gyro real slow for a phase shifting sound projection that makes the speaker seem to be 18" in diameter
I have it populated with vintage Mullard tubes and that really makes it sound EL84-ish
Together they sound like early Black Sabbath
attachment.php
attachment.php
attachment.php
attachment.php
Awesome. I'd love to hear that. I'd even bring over my Tycobrahe Parapedal for the occasion.
je
There's some really nice stuff here everybody! I know you enjoy them.
I figured that I'd post a couple of the only old amp that I still have.
I used to have a bunch of old blackface Fenders and a tan tolex/ flat script '62 Bassman and cabinet, old Ampegs and other stuff that I can't even remember now. heh.
For some reason I've kept this little Gibson GA-5 Skylark. It's a '58, I believe. It has a '57 date volume pot, but I think these were made for the '58 and maybe '59 model run. ~shrugs~ ..pfft..I don't know and don't really keep up with all that vintage stuff much anymore. I did all that for years. I hope the folks that ended up with all my stuff is having fun with them! heh.
She's a nice little amp with just about the same circuit as a tweed Champ and a Utah speaker. A blistering 4 watt output too! woohoo!
I've been replacing the electrolytics and will be changing out the other capacitors soon as well as a few resistors.
Cute little thing, huh? Kinda like it oughta be on charm bracelet or something?
Thanks for reading.
"rr"
That little Gibson looks uncannily like a Fender Champ 600 from the back!
Here's my re-housed Champ 600. It's now running a Jensen c8r speaker and NOS RCA tubes.
Just got the speaker back from Weber yesterday. They wanted to keep it, as it was apparently one of the first made and is quite desirable now. I declined.
