OK, lets get our technologies in order. A surge protector is not a power conditioner. A power conditioner is a device that takes fluctuating and dirty power and outputs clean stable power. This is usually done by charging a large battery and inverting the DC to sine wave AC. Here are the specs for a typical commercial power conditioner:
* Voltage Regulation: +/- 3%
* Load Regulation: Typically better than +/- 3%
* Overload Capability: 125% for 10 min
* Surge Capability: 150% of rated output
* Input Operating Range: +10 to -40% (typical)
* Input Current THD: < 5%
* K-Factor: 30 or better
* Operating Temperature: 0°C to 40°C
* Common Mode Noise Attenuation: 120dB
* Transverse Mode (Line) Noise Attenuation: 70dB
* Spike Attenuation: 3000:1
* Crest Factor: 3.5:1
Input operating range is from about 152 VAC to say 70 VAC or so. I have worked in environments where this was a regular occurrence (sag or partial brown-out). Do any of you'all remember the rolling brown-outs in Calif a few years ago when demand exceeded generating capacity? Or, have any of you lived near a shipyard? Either will wreak havoc on your audio gear. A good conditioner can sometimes be a godsend
See the noise and spike attenuation, that's what makes the average daily improvement in sound. But supplying clean regulated AC means you never hear what's going on outside your system
