The Fuxtor
Addicted Member
I sure like my rebuilt Hafler DH-200 with original MOSFET finals. It always seems to surprise me when I rotate it in the mix.
if someone set up a blind test with my adcom 5200,5300 and b&k vmr 654, i think it would be hard to pick what was what. they all sound great. i do like the distortion indicators on the adcoms as i tend to listen to metal too loud at times... but speaking of metal, my nikko na-2090 integrated is not mosfet and i prefer it for metal over anything else i own and it's not the most powerful. it's actually in rotation now and the b&k is shelved. not that the others are slacking with anything i throw at it but the nikko is edgier.
if i could only keep one it would be the b&k because i have put it through 20 years of abuse and it was still working when i recapped it last year, and it sorely needed it.
the adcoms and the b&k are "dual mono" designs with separate windings/rectifiers/ filter caps for each side.
the 5200 you can bias the crap out of it and get a lot of class a if you can dissipate the heat. somewhere there's a thread on it and nelson pass chimes in. i don't run mine that hot.
dunno what else to say and i can not comment on the others
Going back to my question, do you guys know which brand has the advantage when it comes to Mosfet; Adcom 5XXX, B&K, Hafler, Sherwood 6040, Nikko and Soundcraftsmen?
They are very similar on price and specs.
the only dual mono are the BK 442 and the Adcom 5500 ?
Separate windings on the same transformer core would disqualify it as strictly dual mono. As one winding draws current the magnetic field in the transformer core approaches saturation and affects the voltage/current in other windings on the same core.separate windings for each side on the same transformer.
if you go back a few posts i have dual mono in quotes. i guess i should have put it in quotes everytime , huh?Separate windings on the same transformer core would disqualify it as strictly dual mono. As one winding draws current the magnetic field in the transformer core approaches saturation and affects the voltage/current in another windings on the same core.
Sorry, I missed that.if you go back a few posts i have dual mono in quotes.
I wouldn't say it's simply a matter of semantics. The current drain on one winding having an effect on the other is easily observable with simple measuring equipment.so where do the semantics end, with a separate power feed to your home from 2 power plants?
there are more than a couple amps out there labeled as dual mono that only use one transformer. but yes, if we want to split hairs you are correct, a true dual mono amp will have dual transformers but they are still sharing a common power cord and a common outlet and a common home circuit, which is possible(though unlikely) that one channel pulls so hard that it affects the line voltage/current to your outlet and affects the voltage/current to the other transformer.
it's kind of semantics but not entirely. it's a lot of marketing for sure.Sorry, I missed that.
You could have two different outlets on different legs coming into the home.
The KVA rating of the pole pig is more than sufficient to handle the current requirements of any amplifier.
i think over half of the members here claim that they don't even listen loud so the point then becomes moot. but yes, you are correct.
i almost said dual feeds from the pole but i went the extreme route.![]()
Yes, just call up your local PoCo and ask them to install two pole pigs for your home, and your home only. No need to share with anyone.![]()
that may help, so far this summer my voltage is 115-116 during the day and back up to the normal 122 by night. luckily i have nothing that demanding and i'm not that critical. i can deal with what i have.
if i had another feed to the house it would be for my garage only. small garage but i'd love to have 4 or 5 20a circuits out there
That is odd. We don’t have lower voltages here. It is constant throughout the day and night. And I am sharing that pole pig with two other houses.
I tried to get the PoCo to hang a 3 phase pole pig for my garage at a former house. They would not do it.
