Little Bear Tube Phono Pre??
It sounds pretty good out of the box but it is noisey . I would love to know if grounding pin 9 will take most of it away. Will see after I do the soldering tomorrow.
Have you checked the Voltages at the Blocks? The 6.3v & 15v for the Heaters are Very Important. They were 7.3v & 18.2v on mine. I used Diodes to drop them.
What is the purpose of the bold white arrow with a "J" next to it?
The hum is coming from the tube near the input/output jacks. When I tap that tube it thumps... normal?? or could this be the source of the hum?
No Thumping Allowed! Try swapping it to another Socket and see if the Thump Follows...
Is the Hum always there? Or, does it Increase with the Volume?
How far do you Turn it Up until you Hear the Hum at 6 Feet? You will hear any Tube Stage if it is Up enough...And, this Is the Most Economical Tube Phono Pre that you can get. Mine will get to 12:30 before I Hear It...By then, when the Needle hits the Groove my Neighbors know what I'm Playing...
About 12 at 6 feet...and of course the sub enhanced it depending on it's volume. I normally listen st about the 10 o'clock position so I am OK with it...just wanted to be sure it was not abnormal. My art DJ as I'd dead quite but lacks the warmth and mid range this has.
I have an Art DJ too...And I'll add that that Art also Lacks the Punch that This has...
To lose the Over 12:00 Hum will cost you at least $200.00 more...Or, some Clever DIYing..
I understand... having modified a jd9 and owned a ms22b...this is closer to the jd9 in performance so I made a good purchase. The ms22b falls flat stock.
Yeah, mine sounds very good, but hums like a box of bees. One reason is the gain is so high, I can barely crack 8 o'clock on my preamp. The 6z4 and one of the 6n2's are suspiciously bright. Sled, you mentioned some diodes to tame the voltage, could you be more specific, like what kind and where to put them? Thank you.
As an experiment, I covered the unit with a box of foil grounded with a gator clip and 90% of the hum disappeared. No, I didn't leave it on there! Looks like an enclosure would benefit mine.
I am new at some of this but would connecting a ground from the existing terminal to another components chassis work? I guess it won't. So...simply dropping the assembly into a metal chassis should work and if so how does one ground the chassis?
