Looking for Fuses
mrarroyo
Well-Known Member
Hi, I need to find replacement fuses for a Technics SU-7300. Specifically ...
- 3 amp 125 volt
- 3.3 amp 125 volt
I am also looking for the on/off switch for this unit, a link would be appreciated. Thanks.
125V rating isn't too common any more. 250V fuses of the same amp rating are now the more standard replacements.
3.3A may be an unusual size. IMO, use the closest next smaller rating.
Be sure to use the same type, slow blow or fast blow.
3A should be workable sub for a 3.3A. While you're at it...might be a good idea to examine what fuses the rest of your equipment uses and order spares. Fuses generally come in packs of 5, so you'll end up with an adequate inventory of replacements...just in case.
I have been searching the internet/eBay for the 3A and 3.3A fuses in 125 volts for the last 3 days or so. As stated above I have only found them in 250 Volts and 3 amps. Sometimes I have found the shorter version in 3A and 125 volts but they do not fit.
Sadly, the label in the amp does not say if they are slow blow or fast blow. Do to the lack of information I will go with fast blow to be on the safe side.
I've found 3.15A fuses fairly easily, at least in the smaller GMA size. Those and 6.3A are not uncommon in European audio gear.
John
