Just because it has more wattage doesn't mean it will sound better. There are many other issues at play, so that's just not a good comparison. A lot of wattage is great but if it doesn't sound good at low volumes it will most likely sound worse at higher volumes.
I was using this set up and had no plans of changing. Sound was wonderful, but the Marantz didn't like my eq and some styles of music had a really muddy sound unless I got closer to 12 o'clock. I got the sx-650 for $9 and was a game changer. I use a setting on the eq that I found on here for the HPM's,tone controls flat on receiver and highs rolled way back on the speaker. I tinker with the eq depending on style I'm listening to. I never really go above 9 o'clock and if I do you can easily hear it outside of my house.I never really go above 9 o'clock and if I do you can easily hear it outside of my house.
The best you can do is look for reviews/mentions of each amp on here, AVS, and Audioreview. All of those are still opinion, but can help you at least formulate an idea of what it might sound like to you.So, is there a way to look at the specs of the amp to get an idea for clarity? I know the best way would be to listen to it, but if I'm Ebaying would there be a way to get an idea?
It's great if you like the tube sound, are willing to mess around with tubes, and are fine with the low wattage of the majority of tube amps. However, it must be noted that for those reasons it's not for everyone.for top end sound get rid of those sand amps..A refurbished 25-60 wpc tube amp will satisfy on a level you haven't experienced before....
hunter
hunter
