Luxman L-110 Adjustments
Macon
AK Member
Hello Group,
I have a Luxman L-110 with 178 mv on the left channel and 58 mv on the right. I would appreciate the instructions for adjusting the idle current and DC offset if anyone has it.
Thank you,
Macon
Check out the differential pair transistors in the power amp section. They're likely marked something like Qx01a and Qx01b. x= is the number of the power amp board's components. In Luxman units it is often 4. Replace these with closely matched equivalents (most likely 2SA970 or KSA992).
