videolady201
AK Member-Design Engineer
T/S vs LEAP
First off as you have shown me I can show you. It's not floor bounce it is Half Space Gain. Now we need to agree we both have knowledge of speaker design and quit throwing stones at each others grammar and the words we choose. I know what floor bounce is but it is not the technical name or use and the VAS of the series driver/cabinet of which I listed is not technically correct. The point is I believe we both know what each other is talking about. It is a floor speaker, if it is designed anechoically it will not be linear as you set it on the floor, any floor, it will now have a 6db boost in all frequencies produced by the woofer until the power response start to close in on the woofer. This includes setting it down outside in a field. I have a mid driver that is a NAMM Audio 5" from a 24,000 DBL model speaker. You can run the T/S on it or use the factory specs and it shows it is 89db SPL. Now you run a raw SPL gated sweep and at 1w/1m. The average SPL is around 90db and in the 1khz range and a half octave on either side of 1khz, the output is over 105db. By standard T/S math you would say no way but that is what the driver produces in SPL output. These are the things that T/S can't show or predict. You and I both know why. This driver has very bad resonances at 1khz and is adding in phase to the electronic energy applied to the speaker. The loses I spoke about as you know are frequency dependent and very hi Q. The full specs of the mods on the driver are attached. Without me responding to the rest, please stop and check the math. I think you with see with the half space gain that they are 93db.
Are you saying that with losses you're going to get a 10dB increase in output? Sure, floor bounce is a known quantity. But how are losses adding another 4dB? I'm going to assume you meant pistonic above. If my equations assume pistonic movement then they would have higher efficiency than in the real world with losses.
