I'm next up to bat, I hope. I'm experimenting with some speaker adhesive/dampener that when thinned can be brushed on and seems to soak into the cone material nicely. It's so much quicker and easier and no odor to deal with. I'll post before after images in a day or two. This is NOT in anyway to counter VL's suggestions, people will have to simply decide what works best for them and what is most cost effective. I do not have the equipment to do audio checks to see what impact this has, though my hopes are the same/similar to what VL get's with the superglue stuff. If in doubt, stick with the program. I'm using a set of Mach Two woofers, one of which was noticeably faded compared to the other.
Hey VL, have you run a check between the Mach One/Two woofers? I've compared mine side by side, etc. and the only difference, besides frame color and cone design, is the Two's are shallower. VC looks same diameter, but longer due to the shallow cone. The frames, magnets, magnet ports all look identical. The Two's, of course, are from A.S. systems, but I'm truly wondering if they can be used with good results in the moded One cabinets. If so, I'm one step closer to making a test set to compare to my working One's (which have been capped with original spec caps, before I found out about this thread).
