Too cool, say are yours the 4029's ? seems the newer 4029s are a 4 ohm vs the older what I have 4024s are 8 ohms woofers.read through the thread at 4:00 this morning and perhaps I missed if this was said. the crossover is going to be different in that case.
The lovely marantz...way to go. I have a few put away 2270 and an older intergrated in one of those pretty wood cases.
I did switch the machs over to the ss sumo setup and they sounded better.
good guess is the impedence is a bit tough on the el 34 monoblocks. just fooling round checking all the old tubes may even of been distortion from them.
Now I am really interested in enclosure, the design this acousta reed setup is nice idea to correct phase and back wave problems. man would it be nice to see the inside of the large cabinets. I know what a folded horn sub can do.:thmbsp:
I have the 4024a,s but VL dealt with the differences and decided the same crossover could be used for the 4029, 4024 and the 4024a,s All the caps are the same , the coil values will be the same the only difference is the 4024a has a .2mh coil, a 3.0mh coil and a 1.4mh coil. The 4029 has a .3mh coil, a 2.7mh coil and a 1.0 coil. If you have the 4029 all you need to change is the .3mh if you have the 4024 you need to change all three
