videolady201
AK Member-Design Engineer
Tier 1 Upgrade Question Explained
Tier 1 was for 4029 models only as I did not have nor had I tested any 4024a of which I still had the data. As I tested the 4024a drivers a week or so ago, I found that they are pretty much the same as the 4029!! Both in impedance and more important, in acoustical SPL output! Now, some have decided to do a Tier 1 on their 4024a models. Tier 1 didn't say to change the 3mh to 2.7mh because again it was for the 4029 which already had a 2.7mh. So the changes I just posted a few back are needed for anyone that is going to use the Tier 1 on a 4024a model. NOTE: About the 3mh Coil. If you leave your 3mh just as it is and the lower mids sound thin, then I would wind it down. If you are happy with the lower mids and they sound full, leave it alone! The change will be small, but to some they will hear the difference! Hope this helps.:yes:
ok VL now you have lost me, in the tier one report it never mentioned replacing the 3mh with a 2.7mh. Is it needed and a noticeable change, if so i will remove the crossover and make needed changes.
