Copa1934
My ears are bleeding
You need to remove it from the back. Remove the two screws in the center, then the perimeter screws, then remove the panel. The tough part is removing the 8 nuts that hold the horn in place. They're in a tight, hard to reach place, not to mention long studs. I used 1/4" drive deep sockets to do the job. Once removed can you post images of the horn, including the model and date code on the horn. Many curious minds would like to verify drivers used in the 4024 vs 4024a. I believe they are the same, but confirmation would be nice.
Oh, if you're talking about the hole mods to the cabinet, that's a really tight space to be working in. You'll have better luck working from the woofer end for that. Unless you have an angle drill, which I just realized might do the trick, and I just happen to have a cordless angle drill. Hmmm, got me thinking now. In any case, you'll want a way to collect the saw dust, and pulling the woofer would make sense, as well as prevent damage to the cone from debris falling onto it. You could pull all the insulation out too.
