Brunt
Hi everyone, I recently picked up a pair of Maggie 1.6QRs that were in dire need of some TLC. I'm currently in the process of regluing the wire loop ends back to the mylar but had a question for anyone that has had experience with Magnepans/their repair in the past.
I found after opening up the 2nd speaker that nearer to the center, there appeared to be some bracing(?) hold downs that were screwed through the mylar onto the backing plate behind the magnets, and the wire directly surrounding those had actually not only become loose from the adhesive, but appear to have expanded over the years of their use and are now too long to lay down flat directly in line with the rest of the wire.
It is somewhat visible in this picture, when I get home I'll get some better shots to outline the problem better.
So my question to anyone who has dealt with these or something similar in the past is this: Will gluing the wire back to the mylar not in line with the gaps in the magnets below them be problematic in any way? They bend up like this at all 3 hold down points on the speakers. The only way I would be able to get the wire back into full contact with the mylar would be by pushing them over which would end up creating a bend in the wire at that point.
P.S. I plan to post a full restoration thread on them when I'm finished to help anyone in the future that needs to fix a pair of these, but wanted to ask this question and hopefully fix this part of them before that thread comes up.
