Magnepan MG-IIA Rebuild
The stock Magnepan method from which year? Personally, I disliked Miloxane and much prefer their new method. I do not think the original problem repair in this particular case was caused by an organo-solvent based contact cement such as Dap Weldwood. I've never seen the application of acetone cause the physical change to Weldwood like was shown here in the above pictures.
To the OP: Great job on the repair. They are great speakers and it's very difficult to find conventional speakers that compare at a reasonable price.
I never mentioned either Acetone, nor Xylene would damage the Mylar.
The repair was botched by some gooping on Welwood, or maybe epoxy (if DAp is Good-why not epoxy?) which has to be removed by Xylene-which is more toxic and vaporous then Acetone.
Weldwood does not guarantee future lifting. That's just inaccurate. Neither Epoxy for that matter. You dealing with wires bonded to a large suspended vibrating panel of Mylar. They will fail, and or lift eventually.
I just worked on a pair lately that looked similar to the Op's but went much further down. Had the Gunn Dap repair.
Luckily the tweeter wires were fine, as they were Daped on as well.
Miloxane when done right last for years if cured properly in my experience.
You may have to touch up areas, but is easy to deal with.
Try removing a corroded tweeter wire that has been Weldwood Dapped on.
I read the Gunn article more then a few times.
He got impatient and went with Dap.
Good for him. Unlucky for those who have to repaired Gunn/Dapped Magnepans in the future.
Why they lifted for him-who knows, old adhesive, not clean enough, but my guess was impatience, form the tone of the article.
3M Fastbond is not Milloxane and the 3M product is the current choice. Come to think of it, is Polyurethane Specialties still making Milloxane. Magnepan used Milloxane because it was likely the best choice available 45 years ago. I always thought that Milloxane resulted in too much weight added to the diaphragm; however, I have no data.
The real beauty of Winey's design is the simplicity of the panels and the relatively ease of repair. I'm currently working on some ESLs and they are significantly more complex considering the problems caused by the high voltage on the stators and membrane.
Good luck with your rebuild!
Last time I visited Magnepan in White Bear-the claims was Miloxane provided a bit of damping for the panels.
That's why they still use it one older panel repairs.
It also seals the tweeter wires to prevent early corrosion.
As mentioned it has a UV inhibitor.
I'm all for easily repaired panels, but Dap won't do that.
The Milloxane on the older panels give you this ease-Dap doesn't. Simplicity in design as mentioned.
Personally if these old styles lasted 10-15 years before needing repair that's fine IMHO, because regardless of repair method, those fine tweeter wires are going to corrode and fail by then anyway.
A few easily repaired bass wires isn't a big problem.
IMHO it's also akin to adding coatings to stock type paper cones. It usuallys end up sounding worse, as you aren't taking into account the stock driver parameters.
Same thing with Magnepans, they were designed around a certain weight and dampening characteristic of the O.E. adhesive. These magnets have only so much stored energy.
Just like cone drivers, or even speakers for that matter, you have to take into account all the supporting members. Looking at one particular aspect, the glue, realistically, needs to take these other factors into account.
Perhaps to some, it might be heavy-but I'm fairly confident this was taken into account by Winey.....
