You won't find any manufacturer of a high powered amplifier who recommends using one. If you check your McIntosh manual, you'll find they want it plugged directly to the outlet.
I know what your saying Dave, but I have to smile about the butt loads of folks powering their high powered SS power amps plugged into crusty speed wired 14ga Romax outlets all over the US every day, which of course, causes "mains starvation/power compression" when cranked up !
None of my 4 MC 1201`s are fed their power through a "mains regulator", however the 2 in my bedroom are quite happy being protected with a 120 volt Panamax true 20 surge/spike/ filter sequencer, which has 2 power amp specifically labeled non-inductor high ampere contact relay switching outlets..
The other 2 have been Mac authorized rewired for 240 volts, and are protected each with heavy duty 20amp rated 240 volt Panamax industrial laser printer surge/spike/filter, and the in/out 12ga power cables, that are physically attached to that device, put the provided by Mac as part of the mains voltage conversion kit`s "18ga. IEC" power cable to extreme shame !!
I promptly replaced the wimpy Mac supplied 240 volt plug IEC power cords with 12ga. ones, that originally came with the amps as wired for 120 volts and just cut the 120 volt plug off, and wired up a Hubble 20amp rated 240 volt, and haven't looked back, as I feel my carefully chosen protectors ampacity can and do their job sonically transparently.
Those 240 volt wired Mac`s have broken/separated the glue bond twice between the spider and voice coil on my XRT-30`s 2 of the 4 12" woofers at different times during strong impulse very low frequency bass notes, at realistic SPL, and that speaker system recommends the MC 1201 amplifier in the owner`s manual, so I`m confident that my power conditioning fed setup is not squashing/starving the amps demand for un-restricted impulse power current demands..
I can`t speak for other`s in this respect, just what I know works for my selection & configuration..
Take care and enjoy your weekend folks.
