Ouch not fun but hey your putting in positive work to improve a piece of equipment somewhere, doing your part brother .
Audiofreak71
Yep, fixin those interference problems that don’t really exist
Audiofreak71
Whatever your motivation, it doesn't matter to those who know better.However, ridiculing anybody or anything doesn't make me feel better.
Not having gear that can use IEC based cords definitely poses a challenge for evaluating them!Where does one start?...Unfortunately, none of my equipment on hand, other than a Denon AVR used for HT, has removable power cables.
LOL OK. One man's humor is another man's ridicule, I suppose. What I thought was humor, you took to be ridicule. I think I go out of my way to attempt to help others as often as I can, and throw in a bit of humor here and there, that it should be pretty obvious that I don't post maliciously.Whatever your motivation, it doesn't matter to those who know better.
Oh, I know power strips are multi-outlets. I have a 2U rack-mount Smart-UPS 1500 that filters, smooths, reduces, and boosts when needed, supposedly. It's a smaller version than the ones we use at work on servers, but it's still pretty big. I don't have a real test of its filtering, though I'd like an EMI meter to find out what effect it has.Not having gear that can use IEC based cords definitely poses a challenge for evaluating them!
If possible, I would run digital sources (DAC, CDP, etc.) through a conditioner to prevent it from affecting the AC line. I use several Tripp Lite units for that purpose. "Power strips" are just multi-outlets.
I would not recommend running the receiver or any power amp through a *power strip* nor conditioner unless it's something by Nordost or Shunyata Research. That's where a shielded power cord would show benefits. I use a DIY Belden sourced cord with the Emotiva XPA-5 amplifier used in my HT. Click here for the recipe. 12 gauge, double shielded with good quality components readily available from sources like Parts Express. Running everything else through the APC should be fine.My AVR, sources, 2-channel system, and an LED TV plug into this via the power strips I mention. Most of my equipment is older and doesn't have an IEC connector, which is a pet peeve of mine.
Definitely agree! Especially with stiff cords like the Harmonic Tech model I use for the upstairs power amps which holds its shape.Even if not for upgrading power cords, heavy equipment is much easier to place and trade out without any cords.
I agree about not plugging an amp/receiver into a power strip or conditioner , in my case it grossly degraded sound quality, so I plug my amp straight to the wall and my dac, source and TT are plugged into the power strip, works excellent this way .I would not recommend running the receiver or any power amp through a *power strip* nor conditioner unless it's something by Nordost or Shunyata Research. That's where a shielded power cord would show benefits. I use a DIY Belden sourced cord with the Emotiva XPA-5 amplifier used in my HT. Click here for the recipe. 12 gauge, double shielded with good quality components readily available from sources like Parts Express. Running everything else through the APC should be fine.
Another modest upgrade is to use hospital grade outlets like you find from companies like Hubbell. They provide a tighter connection that the typical builder grade crap. I use them everywhere my audio gear is plugged in.I agree about not plugging an amp/receiver into a power strip or conditioner , in my case it grossly degraded sound quality, so I plug my amp straight to the wall and my dac, source and TT are plugged into the power strip, works excellent this way .
Sorry you haven't experienced better. The first meter does make a difference even when using dedicated lines.If your amps, pre-amps and other components have decent power supplies with a wide margin, you really don't need to be wasting your money on power cables.
I’m in the works of upgrading my outlet my amp is plugged into to a dedicated 20a line , my neighbor is an electrician and we’ve already laid it out , luckily where the circuit is that my amp is plugged into runs straight from the wall back to the garage in one run so it will be easy to upgrade it all .Another modest upgrade is to use hospital grade outlets like you find from companies like Hubbell. They provide a tighter connection that the typical builder grade crap. I use them everywhere my audio gear is plugged in.
You don't need to go crazy with $200 cryo-ed Oyaide models.
You and my wife. I’ll stick with the poutine.Ketchup flavored potato chips! Love me some Canadian snacks!
Mark Gosdin
Granted, if you use an inappropriate filter, yes, it could be a problem.
Or you could choose an appropriately current-rated filter.
The appropriate word here is 'appropriate'.
You'll never find me running Ethernet over power!
Using dedicated lines is always my first step and have enjoyed using them in my current and previous home spanning 23 years.
I'd be interested to know if many use nice locking plugs and outlets. Something like a L5-20R is what I'm thinking. Our standard 120V outlets are a pretty poor design, in my opinion, for two reasons. Friction on the prongs is what keeps the plug in the outlet, and the prongs are not particularly heavy duty. Here's what a L5-20R looks like:Another modest upgrade is to use hospital grade outlets like you find from companies like Hubbell. They provide a tighter connection that the typical builder grade crap. I use them everywhere my audio gear is plugged in.
It's a preamplifier, so the filter capacitor only really needs to eliminate supply hum. It takes very little reserve capacity to drive a relatively high-impedance load with a roughly maximum 2 volt peak-to-peak swing at low current.As a point of reference, your C34 has a one joule power supply (9400 uf @25V). One?
I think that when I run isolated circuits for my audio systems, I'll go with something like this. Especially seeing how stiff some of the power cables many use, something that actually locks in place would seem to be better rather than depending on friction to hold the plug in place. Plus, movement doesn't loosen them. If one wants an even heavier outlet, a L5-30R would do it.
I know that the servers' power strips and UPS's at work use twist-locks. I'm sure this is so one doesn't accidentally knock a plug out of an outlet, but I've noticed that they seem far sturdier than the regular 5-15 or 5-20 outlets and plugs. I'd also connect all new circuits to the same leg in the breaker panel.
The British don't brag! We leave that to our American friends!!![]()
Once when starting a vacuum cleaner I lost 1/2 of a mains circuit cuz upstream from the outlet I was using was another outlet which had a back-stab as part of the daisy chain. The surge current in the vacuum cleaner burnt out the kiss contact in the back-stab, breaking the daisy chain (see solder thread re: mechanical vs. electrical connections). So I redid that circuit and a few others with clean snug screw-terminal connections.Replaced the outlet with a good quality outlet, using the push-in (back-stab) method, not the screws- the backstab's failed. A friend admitted that the 'backstabs' are only good for about 8 amps. Good to know...
