Mains cables...
Yep that's here as well, in both 110 and 220
Yes. Very awkward dual system. You really should consider adopting the UK system. Having lived in the US, Canada, and the UK and experienced the electrical plugs and sockets of all three, the UK system is clearly superior.
Same here but we have two different voltages that's all. Sounds like the UK is wasting energy if you ask me.
Wasting energy how?
Energy consumption is based on consumption, not voltage at the socket.
I don't need no stinking tea:rolleyes:
Hot chocolate, then.
The main downside is that one has to use the plug the British government say one has to use.......with zero thought to differing situations. I think local businesses and local towns are smart enough to figure out on their one what would be the best to use.
You have different plugs and sockets in different towns and different businesses?
Standardisation of plugs and sockets means you can plug in anything that runs on mains current anywhere. Very convenient, that.
By the way, it used to be the case that there were different sockets and apparently even different wiring in different parts of the UK (and one former standard is even still allowable per code under BS 546) which was the motivation for all mains plugs being replaceable and re-wire-able.
I've only ever seen the standard BS 1363 plug and socket, plus a two-pin arrangement for electric shavers in bathrooms.
More than anyone wants to know about it is here: https://en.wikipedia.org/wiki/AC_power_plugs_and_sockets:_British_and_related_types
I'm sure the US standards are fine in terms of fire safety -- though I used to occasionally see charred or melted plugs and sockets in both Canada and the US that I haven't seen in the UK, probably because the UK plug is over-engineered and thus doesn't break a sweat even at 13 amps draw. I presume the dire North American two-prong sockets of my youth have mostly been replaced by now?
Furthermore, it's almost impossible to yank a UK plug out of the socket by the cord; it's typically switched at the socket (handy!) and fused at the plug; makes positive contact over a greater surface area for better current transfer; is designed to make it very difficult for children (or others) to poke metal objects in the socket holes (they're gated) or get shocked by the prongs when pulling the plug out, and they're pretty cheap -- a replaceable plug is roughly 50p, a typical socket pair is £3.50, which seems roughly comparable to US equivalents.
Standardisation means I can plug my air compressor or arc welder into any socket anywhere using the same sockets for my phone charger, lamps, TVs, stereos, computers, washing machine, microwave, stove, clothes dryer, or -- most important of all -- an electric kettle.
The combination of 13amp socket and 240 volts means a typical electric kettle is 3000 watts, whereas the US equivalent runs about 1500 watts. That means you get your tea brewed twice as fast in the UK. If that isn't proof of British electrical superiority, I don't know what is.
On the downside, UK plugs are big -- they do make an annoying lump in your suitcase or laptop case -- but the worst thing about the UK plug is that if you leave one out of its socket, it will invariably land prongs-up to guarantee that you will step on it, bare-footed, in the night for an experience even worse, indeed, much worse than stepping on a Lego.
British electrical superiority? Oh man that's a good one. :rflmao::rflmao::rflmao:
Still driving on the wrong side of the road I see. :rolleyes:
Psychoeletrical Snake Oil
Wasting energy how?
As soon as you turn everything on with more power than it needs.
I don't need no stinking hot chocolate
Do like the sound of a merlin..
Packard made the Merlins for Mustangs AND made improvements to tolerances etc so the engines could be made in the numbers needed for WWll. Packard alone made 55,000 of the 155,000. Ford of Europe made huge numbers also.....far more than Rolls made. British manufacturing methods were so sloppy that Packard said they could not build them without some serious redesign.
If something in Britain is hand built then I trust it......built in a factory? Not on your life.
https://www.tested.com/art/makers/4...mass-produced-britains-hand-built-powerhouse/
Depending on local codes, yes of course. One does not need the same plugs and sockets for every need. Only makes sense.
It can be, but it also can be oppressive and over reaching. In a tiny country like the UK it might make sense but why should a standard that works in New York City be pushed on to people that farm or ranch in Iowa or Montana?
To be fair Germans engineers are the 2nd best in the world! :)
I was on a week long test drive clusterf___ with Opel, Vauxhall, and Daewoo engineers. At the end of each day the Germans would buy the beer and everybody would start ripping into each other. I actually had sympathy for the Koreans - they were just starting out and had not been in the game long enough to make poor quality a national institution like the Brits. And the Germans were excellent craftsmen - but had no concept of net build and good luck trying to get them to put anything on the prints.
Why would a power drill, phone charger, stove, sump pump, computer, arc welder, air compressor, lamp, shaver, television, dishwasher or stereo be any different in New York City or rural Iowa or Montana?
No wonder these threads get locked up! Too many bruised egos get in the way of discussing the merits of a damned mains power cable. However we get electrical power is not the point. This is not the direction the OP has wished for if I'm not mistaken. We are a forum made up of people from all over the planet where it is not important who is the best. We're just trying to share the little knowledge we have acquired over a period of time. How quickly this has derailed, what a shame!
For power cords, many stock cords are cost compromises, and anything better will be better. Then there's diminishing returns for better after that. Shielding, better conductors, better plugs, all that helps. I don't think I'll desolder and disconnect a factory hardwired cable though until I do a bunch of other things.
While there is something to be said about better performance of 220/230V for appliances, one large safety factor lies in the fact that most US houses don't have it. (I have some in my basement and garages). If you get a short or an exposed conductor in a cheap device, you will only ride half the lightning
over here and not experience the full fury of the British Isles.
You wouldn't use original Mullard tubes?
Or fly in a plane with a Rolls Royce jet engine?
Though, yes, Britain is generally better known for inventing things -- like the World Wide Web -- than manufacturing these days.
