Manufacturers Specifications
Lossless
I was looking for a thread that listed members manufacturers amp/receiver amplifier basic specifications. Didn’t see one soo.....
What’s your main amplifiers specifications?
Manufacturer/Brand :
Years Sold: ex 1979-1981
Amplifier weight:
Amplifier Class: A, B, AB. etc
Power Output: watts/channel-ohms, frequency response
Total Harmonic Distortion : into ? ohms
Damping Factor:
Dynamic Headroom:
Pictures or web link:
Fisher RS-Z1
Weight 21kg 46.3 lbs
1989-1991 production run
Amplifier Class - A II / a-ab
Power output - 150 watts/ch 4 ohms from 20Hz to 20 kHz
THD-0.007% @ 8 ohms,0.015 @ 4ohm
Damping Factor: 50
Dynamic Headroom: 2.0 dB
Luxman L-530
1981
Form Integrated amplifier
Effective output (both channel operation) Class-A area: 15W+15W (8ohms)
AB class: 120W+120W (8ohms)
THD 0.007% or less (8 ohms, both channel operation, 15W)
Input sensitivity Phono MM:2mV
Phono MC: 125 microvolts
Tuner, AUX, Monitor, Main In: 340mV
Input impedance Phono man month: 100kohm, 50kohm, 100ohms
Phono MC: 300 ohms, 100ohm, 40ohm
Tuner, AUX: 40kohm
Main In: 47kohm
SN ratio (IHF-A) Phono MM:84dB
Phono MC: 70dB (250-microvolt input)
Tuner, AUX, Monitor, Main In: 110dB
Frequency characteristic 10Hz - -100kHz one dB
Tone control Low-pass turnover: 77Hz, 120Hz, 200Hz, 330Hz, 550Hz, 880Hz
High region turnover: 880Hz, 1.5kHz, 2.5kHz, 4kHz, 6.5kHz, 10kHz
The maximum variation: 8dB
Power consumption 380W
Dimensions Width 453x height 161x depth of 444mm
Weight 18.0kg
Luxman L-530
1981
Tuner, AUX: 40kohm
Main In: 47kohm
Weight 18.0kg
Very Nice!!! Beautiful piece!!!
Fisher RS-Z1
Power output - 150 watts/ch 8 ohms from 20Hz to 20 kHz
Damping Factor: 50
I really like the looks of that Fisher. Had to look up that series and it would be sweet to have that entire series of equipment. Where did you find that piece at?
Power : 2x 200W (20Hz...20Khz ; 8 Ohm ; 0,003% THD)
Power bandwidth : 10Hz...100Khz (100W ; 8 Ohm ; 0,002% THD)
Frequency response : 0dB (10Hz ; DC mode, 8 Ohm)
0dB (1Khz ; DC mode, 8 Ohm)
DC...100Khz (+0 / -0,5dB ; 8 Ohm)
Damping factor : 200 (8 Ohm / 1Khz)
Input : 1,41V / 25kOhm
THD : 0,003% (20Hz...20Khz ; 8 Ohm ; 100W)
IMD : 0,003%
S/N ratio : 127dB
Stereo separation : 95dB (20Hz)
95dB (1Khz)
75dB (20Khz)
PC : 200W (US models ; 1% THD ; 1/10 output power)
1200W (EU models ; 1% THD)
Dimensions : 29 x 17,65 x 29cm
Weight : 9kg (US model)
9,2kg (U model)
Listprice : 190,000¥ (1980)
Can't play using tubes. This is the solid state forum. Guess I'll pick an amp I have used in the main rig, recently
57 pounds
A/B +B
Freq resp: +0dB -1.5dB, 0-80kHz
Damping Factor: >700, 0-400Hz
I was Googling “class A receiver” and a link to eBay came up and it was listed as “fisher class A1 receiver 400 watts”. I said “Holy Hell !!”, well not really “Hell”. No watchers or bidders. Local pickup , very very low starting bid. I waited till last minute and bid and Won!!! I was the only bidder. Talk about lucky day!! Drove 150 miles to Ohio to pick it up. The gentleman was not an audiophile and was just unloading stuff he had in temperature controlled storage for over 10 years. I couldn’t sleep the night before the auction was over. I was constantly checking for bidders or watchers. In Heaven now. I think I have listened to it non-stop since buying it a few weeks ago. From what I have been researching, this may be 1 of only 3 working models in the United States.
Main amp right now is a Yamaha A-1000:
Power output: 120 watts per channel into 8Ω (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.005%
Damping factor: 90
Input sensitivity: 0.16mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 80dB (MC), 94dB (MM), 106dB (line)
Channel separation: 70dB (MM), 65dB (line)
Output: 150mV (line)
Dimensions: 435 x 146 x 424.5mm
Weight: 13kg
Year: 1983
Pic is of an A-950 which looks identical but I've got one of those too.
Damping factor: 90
Weight: 13kg
Year: 1983
Damping factor: 90
Weight: 13kg
Year: 1983
Wow that damping Factor!!
I loved the Yamahas of the 1980s. My baby was a Yamaha CR 1040 until local stereo repair shop repaired blown output stage. Never sounded the same and I ended up selling it close to nothing. It was my favorite natural sounding piece of all time. It was natural sounding until shop “fixed” it.
Yamaha M-2
Specifications
Power output: 240 watts per channel into 8Ω (stereo)
Frequency response: 1Hz to 100kHz
Total harmonic distortion: 0.004%
Input sensitivity: 1.62V
Dimensions: 435 x 183 x 362mm
Weight: 20.9kg
Year: 1979
Man that stinks about your CR. It seems hard to find a good tech these days, especially locally.
I dig all Yamaha for the looks but especially for the sound. Their house sound did change a bit over the years but it's always been to my liking.
Yamaha MX-1
Power output: 200 watts per channel into 8Ω (stereo)
Total harmonic distortion: 0.008%
Damping factor: 250
Input sensitivity: 1.46V
Signal to noise ratio: 125dB
Dimensions: 438 x 116 x 486mm
Weight: 24kg
Year: 1993
