Manufacturers Specifications
Yamaha MX-1
Power output: 200 watts per channel into 8Ω (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.008%
Damping factor: 250
Input sensitivity: 1.46V
Signal to noise ratio: 125dB
Dimensions: 438 x 116 x 486mm
Weight: 24kg
Year: 1993
That’s a BEAST!
Yamaha M-2
Specifications
Power output: 240 watts per channel into 8Ω (stereo)
Frequency response: 1Hz to 100kHz
Total harmonic distortion: 0.004%
Input sensitivity: 1.62V
Dimensions: 435 x 183 x 362mm
Weight: 20.9kg
Year: 1979
I have one of those! Excellent amp.
Since we're playing Yamaha now here's my B-2x
Power output: 170 watts per channel into 8Ω (stereo)
Frequency response: 10Hz to 100kHz
Total harmonic distortion: 0.002%
Damping factor: 200
Input sensitivity: 1.3V
Signal to noise ratio: 124dB
Speaker load impedance: 4Ω to 8Ω
Dimensions: 435 x 164 x 422mm
Weight: 28kg
Year: 1985
Damping factor: 200
Weight: 28kg
Year: 1985
Seems like all the BIG BOYS are coming out to play tonight. Nice!
Yamaha M-80
Specifications
Power output: 250 watts per channel into 8Ω (stereo) (Actually 297wpc--;) )
Total harmonic distortion: 0.003%
Damping factor: 250
Input sensitivity: 1.55V
Signal to noise ratio: 127dB
Dimensions: 435 x 165 x 425mm
Weight: 23kg
attachment.php
Soundcraftsmen A5002
Specifications
Total harmonic distortion: 0.09%
Damping factor: 100
Input sensitivity: 1.2V
Signal to noise ratio: 110dB
Speaker load impedance: 2Ω (minimum)
Dimensions: 19 x 7 x 15 inches
Yamaha M-80
Specifications
Damping factor: 250
Weight: 23kg
Another heavyweight world champion!!!
Carver "Cube" M400
Power output: 201 watts per channel into 8Ω (stereo), 500W into 8Ω (mono)
Total harmonic distortion: 0.05%
Damping factor: 150
Input sensitivity: 1.5V
Signal to noise ratio: 100dB
Weight: 12lbs
Finish: black anodized
Year: 1980
Carver "Cube" M400
Damping factor: 150
Weight: 12lbs
Year: 1980
and in this corner, featherweight champion of the world, “Cube”!
That only weighs 12 lbs and puts out 500 watts mono?
