Blue Shadow
Waiting for Vintage Gear from this century
Yamaha M-80
Specifications
Power output: 250 watts per channel into 8Ω (stereo) (Actually 297wpc--)
Do we know if either of these Bench WPC were tested per FTC regulations? If they were, great, if they were not, those numbers are similar to most other amps in their power class for similar testing. I have seen most amps do 10-30% OVER spec on power when 'Bench Tested', typically a 1kHz signal run to clipping and measured on a warmed up but not pre-conditioned amplifier.Nakamichi PA-7A II
Rated 225wpc in to 8 ohms.
"Back in 1989, when Stereo Review featured the PA-7, writer Julian Hirsch measured the PA-7’s output at 253 watts into an 8-ohm load, 400 watts into a 4-ohm load, and 650 watts into two ohms."
