Antenna att in or out? May need a cleaning
Does anyone know if there is supposed to be any static sound between stations on the 150? It's very different from the tuner on my 2235B as there is no static and seems like it doesn't pick up as many stations. Do I just need a better (dipole) antennae? Right now I'm just using some speaker wire plugged into the FM connections in the back.
Also BK, any idea where to buy a blue transparency?
Anybody know if it is possible to convert the green scope of a 150 to blue? I read that some of the later model 150's had a blue scope which was achieved by added some blue gel filter (lens) in front of the glass. Is it possible to just buy the gel to modify the color?
Also, how do the scope inputs work on the tuner? Can I just plug in my main out from my amp to these inputs so that the scope also works with the output from my amp?
I have the speaker wire hooked up to both taps on the back.
The scope looks like this when in multipath mode: http://www.ebay.com/itm/MARANTZ-MOD...D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
I'll check and see if there is a muting threshold on the back.
