Aaron99
Recently I have acquired a Marantz 2010 in decent cosmetic condition. It was known when I purchased it that it would not power on.
I put it on a DBT and I get no light at all. Do I need a less wattage bulb, it currently is a 75Watt incandescent. I have used the DBT successfully testing my 2220.
I tested the fuse with multimeter and there is continuity.
Popped the hood:
P800 no voltage on any of the jumper pins.
I replaced the electrolytic caps on the P800 board. With same capacitance and slightly larger voltage.
P600
There was a a couple of heated areas on the P600 board: R648, R650.
A resistor was replaced by previous owner(s): R639. It looks like it got hot under the resistor.
I replaced R648 and R650 with 3W 0.5ohm wirewound resistors which is what was in it and the service manual calls for.
I replaced R639 with a 220ohm metal film resistor.
No change. Still dead and doesn't light the DBT.
When plugged into DBT I measure 120VAC across the switched and unswitched outlet. This is the case with the power switch on and off. This seems odd that even with the power switch off that there is power on the unswitched outlet.
When testing the power switch, I test from ground to either contact and it measures 99VAC with switch on or off. Again, this doesn't seem correct to me.
Any thoughts on helping me save a baby Marantz?
Popped the hood:
P600
