I think it’s variable in that it can be dimmed maybe. Not sure. There’s no setting on it.Never seen a variable wattage, incandescent bulb before. Is it set at the highest, or 75W? Fixed wattage, incandescent is the way to go.
If the bulb appears to go dim, that generally means no shorts. It's when the bulb gets brighter and brighter, or never dims, that it's drawing a high amount of current, and indicating a short.
Did you replace the three big caps?
Thanks, that’s good to know. I’ve certainly been tempted to test without the DBT, but it looks like my regular 75W bulbs arrive tomorrow.If you're still concerned something could be wrong, like the direction of a cap, or the orientation of a replacement transistor's collector leg being in the wrong spot - I'd wait for the true 75W incandescent bulb, for insurance.
I've had it happen to me that powering the amp on a DBT with too small of a wattage bulb, 60W with a 2275 specifically, limited the current so much I couldn't supply the correct current to the 2275 to operate correctly. Once I took the DBT out, it ran like it was supposed to.
Sure, I'll do that in a bit. I carefully checked the pinouts and made sure the pins were in the right holes, which did require some twisting. I'll get some better pictures too.I can' tell from the photo, but did you verify that the replacement transistors are installed with the correct leads connected. Some look like they are twisted to install. Please list the H# and replacement transistor for each that you changed. I apologize if you already listed it earlier in the thread.
