Here are the parts I used:I can' tell from the photo, but did you verify that the replacement transistors are installed with the correct leads connected. Some look like they are twisted to install. Please list the H# and replacement transistor for each that you changed. I apologize if you already listed it earlier in the thread.
| Part ID | Service Manual | Replacement Value | Replacement Brand | Replacement PN | Mouser Link |
| H701-H702 | 2SC945 | KSC945 | ON-Semi | KSC945YBU | KSC945YBU |
| H703-H704 | 2SC853 | BD139 | ON-Semi | BD139 | BD13910STU |
Oh.. I didn't even think about the suffix when ordering. Thanks!Looks like parts were installed correctly from what I can see in the photos. Could have ordered the C suffix to get the matching ECB pin out. Thanks.
Thanks! I guess I'm not sure what the next step is. Maybe I need to assume I broke something in another part of the receiver while working on the power amp board.When I recapped my receiver (52W), I started testing using a 40W bulb then went to a 60W bulb, so a 60W should be fine. Normally, it should glow bright for the first 3-4 seconds then dim down to a low glow. So, to answer your question, YES... you probably have a short somewhere.
I verified with a DMM that the negative side of the C711/C712 caps are connected to the bases of H703/H704.Can you verify the installed polarity of caps C711, C712. (See diagram below) i don't know if it's your particular board or not, but the SM of C712 shows + 'UP' on the diagram and your photo seems to have a + on the silk screen towards the bottom. C711 & C712 seem to be oriented 90 deg different than the diagram? The schematic shows that the (-) should be connected to the base of H703/H704.
