Marantz 2220B problem.
Here are places that need to be soldered again:
More pictures of the board will be useful. Move the transistor sockets to the side so more traces and solder points are visible. The more angles you take pictures from, the easier we will be able to see your progress with resoldering.
I'd contact the seller and tell him you have the 2220B model with the LC hazy/translucent relay and see if he'll help you with a refund including return shipping cost and/or supplying the correct relay.
Sorry I don't know. I've read that these can be problematic but I don't know if that's your issue necessarily. Wish i could help but I don't know what to suggest, maybe others will chime in. If it worked at one point (clicked) then it may not be your biggest problem.
Sorry I didn't mean to post that last thing...
This site just seems to do whatever it wants sometimes I see..
I'll touch those up. I think I already have done that to a few that looked questionable. But will do.
Still no luck so far though.
Sorry didn't mean to post yet...
Do you know what these little circles are??
The boards were made like that but I don't know what they are....if they block the signal to the other part of the trace or what...
Is there a hole in the board there with no part in it, and the hole is just covered with solder?
It looks like one of those peel-and-stick pads. Is it rubber or plastic? Hard to tell from the picture!
