While I'm going though my pics, I have a question about these three ceramics and ceramics in general.
Over time these get ringy and noisy, etc. I'm wondering about C0G/NP0 replacements
for them, thoughts?
But, not on the AM/FM boards.
In the following pic:
Circled in red C762 this Mica cap. Now I've got some other questions
as I'm getting ready to work the amp boards:
.1 uf 20 0 WV caps, Matsushita r2X, are these the caps to keep
in circuit or change out for better caps.
White 26 numbered resistors? Are these asbestos coated that looks like paper?
What do we know about them?
I started to pull the heat sink off one of these driver transistors, and when I started feeling
the leads bend as I rotated to remove to clean them...I stopped. They almost feel
glued on, or maybe grease that hardened and dried up on them.
Otherwise it would be desolder to pull and clean, or when the amp board is pulled,
better access to clean them.
I ask because I don't know, this is my first Marantz and y'all have done this a time or two or more.
It's a gift for my little girl so it has to last and sound great too. That's my goal.
Now w
Looks simple enough to pull the board, the red, green blue, and two whites along with
the ground strap. Not sure I can get at that screw properly, (yes I do have a couple of
90* screw heads, stashed somewhere.
That seems to be par for the course now days.
Once I start moving stuff around, it's hell trying
to figure out where I put it, in a safe place too.
Like I've been looking for the thin copper tape I bought
just to use to replace the trace pulled off the regulator board.
cut a strip 1/2 long, 1/4 wide, acetone 1/2 the adhesive off the back
Spread a dab of paste flux on the board trace, then lay it down with the cleaned copper
on the trace with the adhesive end to the terminal. Apply heat
and over the trace end and let the solder be wicked into it,
making a good everlasting joint. Then I solder the terminals
and it's good to go.
Instead, I'm running a jumper wire around the terminal
to the trace and soldered it there.
But then, I'm preaching to the choir here.
