LFazio51
The reason i like the cap checker, is that it does transistors also. Its great for checking inductors also. If your messin with speaker crossovers.
Update: This one i have, i just found out, is actually a trans tester that does caps also. here are some pics. I paid less than $20
No doubt! Looks like way more value than the Peak Electronics units at roughly $135ea! Do you know if its possible to check the components while still in place?
If the latter, then I can only assume that when replacing transistors in the same circuit, the hFE must match? Trying to learn here my friends...
Good catch.
