LFazio51
I would also replace the power switch as there is a very good chance it will die in the next few years. Not sure if the 2265 uses this model as well but most Marantz models use a common & cheap (under $3) switch like this one from Mouser - p/n 612-P227EE2B20A. Perhaps add a snubber cap (eg 80-C981U103MYVDBWL20) and 120 ohm 1/4 watt resister as well.
Bluehills5, the SM calls the switch "S002" but I cannot locate the actual part no. anywhere in the manual, therefore, I'm not sure if it's the same switch that you're mentioning. It does in fact appear to have a resistor and cap attached (see below).
