The volume control is wired up as an attenuator. "Full strength" audio is received from the source and the volume controlThe signal at RE09 and RE10 are also showing a signal but very faint in comparison to Volume pins.
will give you from 0% to 100%. The input pin will have the full strength audio and the wiper will have the 0%-100% depending
on how much you turn it up. So it's not unexpected that the RE09 and RE10 are much lower than the input pin/Pin 7,8
Resistance measurements between vol input and wiper look ok.
The volume pot is probably ok, you may have a gain issue which came about after recapping PE01 board.
If sinewave at RE09 and RE10 are about the same level then possibly a power supply issue to HE01 & HE02, measure
dc voltage at pin 10, expect about 35Vdc
