Steven Tate
CEO Flat Forehead Soc.
Looks like the power amp boards are good. MBZ is much better than I am at diagnostics. I’ll bet he will be able to help you track down where the missing link is in the preamp signal.
Strongly disagree, your input is always welcomeMBZ is much better than I am at diagnostics.
Input to Vol pot (pink/light blue) and wiper (red/blue) basically the same.
Pre-out Left is significantly lower than right, so problem between left
wiper and left pre-out. However it would be nice to verify power amp
as suggested.
Below are some more test points, the idea is to work through the audio path
and make comparisons between L&R channel to work out where it goes pear shapped.
Points with same colour should have same size waveform.
RED RE09/10
PINK HE01, 02 output pin 6
BLUE RE21, 22
YELLOW RE57, 58 after switch
Lt GREEN PE01 connector Pin 13, 14
Suggest work from bottom up, start at pin 13, 14, if they are ok then no need
to check further back
EDIT: Work both the Hi and Lo filtyer switches a few times, any improvement on left waveform?
Need to confirm the inputs (signal, power) to HE01 are ok, if so then HE01 suspect.
Check waveform at RED marks HE01 input pin 2 and HE02 pin 2 for comparison.
Check dc voltage at pin 7 (again, intermittent?) at green marks, 34Vdc expected.
With amp powered off measure resistance across RE17 (5.1k).
Check CE13 (3.3uf/35V Wima next to HE02), looks larger than CE14
Points to HE01 (BA312) as being suspect faulty. Need one of the Marantz specialists to chime in with
latest on replacement options. Items on the bay likely to be fakes, also there is a replacement item, engineered at
a high price. What is the main purpose of the IC? it does provide some gain, any datasheet available?
Mike, mbz nothing to do with mercedes benz, kind of an acronym for my name...By the way MBZ, what's your name?
Yeah, I saw this site, wasn't really keen on the idea. BA312 equivalent circuit was 3 transistors and 4 resistors, the sparkoI decided to replace both BA312 with the Sparkos Labs BA312-M.
kit has "dozens" of parts...are they trying to justify the steep price? On the other hand, if it gives the performance improvement
they say, it would be a cheap investment.
Once you sort out the PE01 board I think you should have the power amp looked at by one of the AK Marantz techs.
I was a little concerned about the smoking and clipping you mentioned earlier
Appears that the wiper is intermittent giving the conflicting test results.
I would (initially) resist the temptation to buy the ebay item that seems to be a perfect match. Try to find
a quality item and adapt from there. 4 pin pots are harder to find not to mention finding the wanted shaft
length etc... Maybe wait for the marantz gurus to chime in, they will have been through this already. I
will do a search later in the day
RE05/RE06 are OK so need to look after this point. Audio path is then RE09, CE05, HE01-pin 2/input and HE01-pin 6/output. Need to check the feedback path CE11 and RE17(check this). I would check bias and set. Maybe try some
freeze spray on the abobe RE's and CE's, only a short spray. Don't see the right power amp causing this but it might
be time to have a look at what's getting hot. Only use low volume, 9o'clock position, the 2325 is something of a beast
tCE09 shorting to GND? Need to review, has it been replaced/inserted correctly?I have another 2325 waiting to be recapped and removed the Volume wiper from its tone board. I installed it on the PE01 we are currently troubleshooting and am seeing the same sine wave results from the LEFT side as noted in POST 50. It now appears Volume wiper is not the problem.
Measure resistance between points in yellow, should be open. Give this area a clean with acetone or circuit
board cleaner (acetone will damage plastic) and post an updated pix.
Not sure I understand. One meter probe on one solder blob, other probe on other blob, amp powered off/unplugged.The Sparkos Labs BA312-M's MOD requires the removal of several components in this area so I can't measure the resistance between the two points in yellow
Speculating that CE09 was leaking to GND, however it appears new, possibly replace to rule it out as suspect.I resoldered CE09 and GND. No change to the sinewave signal.
