Thank you soo much just saved me a ton of work. Repairing a Marantz 5400 recording deck.Well, I did another data dive and compiled a fairly comprehensive list of 99% of the transistors and diodes used in 70's era Marantz stereo integrated amps and receivers. I scanned threads until I was blue in the face, and scanned the internet for specs. I searched every Service Manual to pull a list of transistors and diodes. I looked for recommended subs throughout the threads, and collected the ones that were repeated often, or that someone had successfully used. I can't be sure of the appropriateness of any of the listed subs, but these are the ones I would start with if I were looking for a sub. I tried to search for availability, and only use subs I could find. Many recommendations that I came across turned out to be obsolete. I'm hoping the gurus will take a little time to scan for obvious problem suggestions, or to fill in blanks where I couldn't find any info. Please let me know if you find errors or have better suggestions for any sub. So, here is a link to the Excel spreadsheet on my Google Drive and I am attaching a PDF for those that don't have Excel handy. Give me suggestions on how to improve my list! Search for your transistor or diode in the left column (alpha order), and look for subs in the columns to the right.
Spreadsheet:
https://drive.google.com/file/d/11a0YpNoHxK-PQYfmikAL3U10215_ocn7/view?usp=sharing
- bumpIs the one currently up the latest?- bump
Make sure to download the latest![]()
Yes. I have started dating the title, but it doesn’t show up in the direct link. It does show up at the top of the pdf download. If you see errors or have suggestions of better subs, let me know.Is the one currently up the latest?
I've asked one mod to make it and the Marantz Control Cross Reference sticky, but no response one way or another. I think both documents can save a ton of time.Nice Steven. I printed that off. Thats a heap of work saved for anyone looking to replace transistors/diodes.
@Grumpy, @RayW, @Negotiableterms - Please! And while we're at it, this Marantz Control Cross Reference could be a great sticky reference. Both took a lot of time to compile for the purpose of preventing having to do a lot of research in the middle of a rebuild. Thanks!Could we please have this be a sticky? Could we also please have someone be appointed to sticky items in the Marantz forum, for the future?
Thanks!
Depends on what it is used for, and the circuit it is in. Many times a 1N270 will work satisfactorily. Germanium diodes are long out of production. Sometimes certain Shottky diodes will work fine too. Although you can find some genuine NOS 1N60 and 1N60P, as well as 1N34 and 1N34A germanium. I have a small stash of 1N60 for those "just in case" times.Is there a known replacement for diode 1N60?
I got a small stash of 1N60's at Mike's Electronic Parts.Depends on what it is used for, and the circuit it is in. Many times a 1N270 will work satisfactorily. Germanium diodes are long out of production. Sometimes certain Shottky diodes will work fine too. Although you can find some genuine NOS 1N60 and 1N60P, as well as 1N34 and 1N34A germanium. I have a small stash of 1N60 for those "just in case" times.
