TL;DR.
Main`s starvation (excessive voltage drop) has a decided effect on the dynamic`s SQ of high quality high bit depth digital recordings !
Especially trying to drive inefficient, but high quality speaker systems, like I discovered upon purchasing my Mc. XRT-22 in 1990, when the playing SPL`s were advanced to realistic levels in my fairly large open plan living room!
These excellent sounding line array speakers couldn`t realize their full potential being powered by one 120 v wired Crown SA-2 power amp, and was readily apparent to the Mc. dealer`s experienced installers, and myself, as soon as I fed the system a very dynamic DDD CD within a few minutes !
Ok, I need to track down and purchase another SA-2, and mono configure both... Better, but the system still lacked the punch that I heard at the dealership after auditioning them for most of the day (my first Mc. speaker purchase ever and at close to $10 grand !) prior, playing the same highest quality CDs there, that I did when I received my pair.
I was powering my Crowns off one of the living room`s string of 15 amp circuits, that I had already un-wire stabbed and wire wrapped around the outlet`s connection screws, like I did to all the house`s outlets before I even moved in a yr. before, so my thoughts were why am I not getting the dynamic impact that I should with all these 2 SS big amp high horse power amps ?
So I started thinking maybe I have to high of a peak demand 120v AC input voltage drop through the living room`s 14ga. wired 15 amp shared outlet circuit ?
So I got out my very trusty HQ very fast responding VIZ brand 120 v plug in AC voltage monitor, and plugged into the next nearby shared outlet in the living room to see how much the voltage of that circuit dropped with the system turned up to the highest SPL that I would listen to sitting on the couch.
That AC line monitor acted like a crazy inverse displaying VU meter, dipping down as low as 10 + volts during high dynamic DDD CD music passages !
Ok, there you have it, I said to myself !
Now, what to do about this dynamic music main`s AC starvation inexpensively ?
I called up my long time very handy man friend, and asked him to help me run a 30 amp 240 v 10ga. circuit with 2 separate outlets to the wall by the amps.
I then had these big Crown amps brought to my bench and I rewired them each for 240v and full factory spec. (I was a authorized Crown service center, at that time) retested them each after I had rewired them plugging into my benches 20 amp 240 v circuit.
Reinstalled them, changing nothing else, but powering them with 240v.
Ran the same three or so DDD CDs with the same cranked up to the maximum listening SPL that would ever listen to !
Well, that did it, "total airiness" to the sound with no perceptive SQ compression!
Some yrs. later in 1997, I decided to retire the getting long in the tooth 1970`s era SA-2s and upgrade to 2 Crown Power Tech 3s to up the power per channel mono configured to 1,500 watts at 8 ohms each after getting special permission from Crown to order the export only, multi input voltage capable version amplifiers for wiring to 240v
I guess I`m tainted/spoiled having been a FOH sound engineer mixing a high powered Bi-amplified HQ components (JBL, EV, etc. Crown, PL, ect.)of my creation PA for 2 yrs. @6 nights a wk. so I had a good experience of nightly hearing live high dynamic music with 3,300 watts RMS output power with a 100A 120V dedicated on stage sub panel circuit fed with zero main`s starvation effects.
My long time friend and next door neighbor, who`s a classically trained flute playing, bat eared, also ex-FOH engineer B-I-L, shares the same dislike of excessive input voltage drop mains starvation compression effects, and we`ve learned to not rely just enough circuit capacity, is good enough, but use our intuition and experience with live music`s dynamics to guide us in providing more than just "predicted/calculated" acceptable based ample voltage drop/available current to power our powerful stereo systems, for best dynamic performance and headroom, but instead trust our bio based built in test equipment (ears).
Folks, do as you see fit, as I have and do for me !
