The barriers on the `terminal strip´ get broken when a slotted screw driver blade isn't relatively centered on the screw, and the torque will snap the barrier ends off. Typical of someone who can't see well.
That's the reason for replacing he screws with Phillips, they're self centering. But everyone knows that, right.
-Greg
You’ve convinced me to maintain the Philips screw upgrade. My Vessel JIS screwdriver really does fit them nicely. I was on the fence about disrupting the originality of the unit by using the Philips screws, but I have to be practical here. Besides this amp is far from original at this point anyway.
The main fix here was to get the solder repaired terminal out and also the spinning ground screw that would never tighten up fully. I couldn’t live with that! In the process I ended up with some much less chipped up terminal barriers.
