MC2505 catastrophe
Is the 725mV of DC the same amount in both the left and right speaker out?
Is the 66 mV the same in both channels?
I took new measurements, here's what I get:
Left channel: 743mV / 80mV
Right channel: 727mV / 53mV
EDIT: the amp is completely silent when it's on, no smells/smoke or anything like that.
All of what Monk said above -
Do wonder if the speaker switch is way dirty -- after cleaning, be gentle- but give it a good working...
Out of curiousity, how did the 4 sections on C33 read ?
Nice looking install of the Vishays.
Awaiting good news ...
Under Schematic notes in the SM --- it says tests made @ 117V...
front panel controls:
gain pots fully ccw
meter range switch Off
etc ...
Do you own a cheap pair of junk headphones you don’t care about? If so, I would power up with speaker switch off and plug in a music source. See if the amp is passing any music to the headphones and what the music sounds like in the headphones. Does music sound normal in the headphones or is it distorted or not passing music etc.
Check the voltage at pin 8 (brown wire) of the driver board with the speakers OFF. You have ~700mV of DC at the output of the autoformer, which is a low resistance to ground. There's obviously a fair amount of current going through it and you're running the risk of frying it.
You could have an ultrasonic oscillation. Only way to tell for sure is with a scope.
I wasn't entirely succesful testing the diodes when I did it days ago, I keep getting values both ways (more on the correct direction however). Will try again.
There are two DC trim pots on the input board:
@Benz just to clarify, did you say your DBT bulb shone bright when you powered up with the speaker switch on?
And did you say the DBT bulb was dim when you powered up with speaker switch off?
And earlier when you said you turned the speaker switch on (after the unit was powered up with speaker switch off) did the DBT bulb shine bright or did it remain dim when you turned the speaker switch on?
Sound through headphones is clean and clear, no hum or noise, good clarity, and VUs are working normally.
yes, correct
@BenzAnd did you say the DBT bulb was dim when you powered up with speaker switch off?
also correct
@BenzAnd earlier when you said you turned the speaker switch on (after the unit was powered up with speaker switch off) did the DBT bulb shine bright or did it remain dim when you turned the speaker switch on?
it remained dim
yes, correct
also correct
it remained dim
This is really interesting. The DBT is acting like there is a short if you power up with speaker switch on. But if you power up with speaker switch off and then turn speaker switch on, the DBT seems happy?
And there is a massive difference in DC on the speaker outs (725mV vs 50mV via the first vs second power on approach).
What would cause this repeatable discrepancy? I would ask @Bob the Tech and see what he thinks.
With the speaker switch off, I get 87mV at pin 8
That's good. Adjust R1 and R2 for 0V at that point.
Next, power off, check DC continuity between all speaker terminals and chassis ground (no speakers/headphones/dummy load connected), speaker switch off. Wondering if you have a bad ground on the autoformers, or an open winding.
I was able to adjust them to 13mV (left) and 7mV (right).
Continuity is good on all speaker terminals.
I was able to adjust them to 0.13V (left) and 0.7V (right).
Are these readings after pot adjustment taken from the speaker terminals? That's 130 mV and 700 mV of DC, respectively, which is still high.
Under what conditions did you take these new readings vs the earlier readings below:
Sorry, did not proofread and typing too fast... those values are 13mV and 7mV respectively.
That's much better! To clarify did you reduce down from 743 mV to 13 mV? Or did you reduce down from 80 mV to 13 mV?
Are these new readings from power up with speaker switch on or power up with speaker switch off, then speaker switch turned on?
From 80mV to 13mV. The speaker switch was off and the amp turned on. I will test at the terminals again with the speaker switch on (under scenario where issue is present) to see if there is any change. Will edit this reply with results shortly.
EDIT: 728mV (left terminals) and 745mV (right terminals)
Will be interesting to see what Bob The Tech says. Could a fault in the Sentry Monitor circuit cause the issues you are experiencing?
Is there any DC at the speakers terminals if the speaker switch is set to off?
And the 13mV DC reading is if you power up with speaker switch off, then turn the speaker switch on?
And the 728 mV DC reading is if you turn on the amp with the speaker in the on position?
