MC2505 catastrophe
By the way, for MC2505 owners, I noticed a factory error in my 1972 unit. I believe the term is "McInstake." :)
Check the temperature of your left and right channel output transistor heat syncs. If you don't have an infra-red heat gun, put your hand on the cage over the heat syncs and feel for excessive heat and temperature discrepancies between channels.
The right channel heat syncs on mine were about 10 degrees warmer than the left. I initially thought I might have some out of spec components on the right driver board. But they tested OK.
Long story short, my amp was missing a 47 ohm carbon comp resistor (R60) on right heat sync under the cage for Q24. It was apparently a factory error and was accidentally omitted back in 1972.
I added the missing 47 ohm resistor and the heat sync temperature is now in line with the other channel and not getting hot. The original owner didn't notice the issue with one channel getting hot as they had it in a wood cabinet. The missing resistor wasn't enough to send the output transistor into thermal runaway, but it was enough to throw off the bias and heat up the transistor which in turn heated up the heat sync.
Just goes to show you that the Mac factory did occasionally make some mistakes during assembly that passed inspection. Below, you can see that Q23 has the 47 ohm resistor shown in the schematic, but Q24 does not.
Benz must be hard at work -- maybe that's the sweet smell of solder coming clear from Canada I smell....
Onward we go :)
Onward indeed, just finished building my DBT... and supposed to receive my new variac later today. I've laid out and prepped everything in the amp so the wiring and caps are ready to be soldered. That will likely happen tonight or tomorrow am however as life is getting in the way this afternoon/evening. Cheers
Soldered in the new C34 replacement caps this morning. I brought the amp slowly up to 120V, going through the DBT. There is no more hum (the initial issue I was trying to resolve) and the VUs are no longer pegging so things look positive. The filament in the DBT bulb (60W) is barely glowing when I reach 120V; I assume that is fine? I did turn on the speaker switch on the amp and still no funny business. I haven't hook it up to a source yet, nor have I connected speakers to the amp.
Looks like I'm not out of the woods yet. I turned the speaker switch and off a few more times, and with the switch turned on the DBT bulb gradually gets very bright as I increase voltage. The VUs also start pegging as voltage goes up. So I'm thinking the switch might be bad or there is something wonky in the output circuit. Will do more testing.
EDIT: With the variac at 120V and the DBT glowing brightly, I get approx 725mV at the speaker terminals, so it looks like DC is flowing through to the speaker outputs. No hum like before however.
I'm observing a peculiar behaviour:
- turn on the amp (full 120V) with the speaker switch already on: DBT glows very brightly + VUs peg + I have 725mV at the speaker outputs
- turn on the amp (full 120V) with the speaker swicth off, then turn the speaker switch on (after power up): BDT filament barely glows + VUs stay at zero + approx 66mV at the speaker outputs
Is this repeatable?
Is the amp behaving any differently now vs the fault you observed a couple of weeks ago before you replaced the C34 caps? Or is the fault behaving the same now as before?
Did you test the diodes in the power supply (with the power off)? Did they all check ok?
Did you spray any contact cleaner into the speaker switch (with the power off) and work the switch back and forth a few times?
Is this repeatable?
Yes, I've gone through the sequence a number of times, and I always get the behaviour described above.
The hum I had when the issue was initially discovered is no longer present. The VUs pegging is the same however.
It appeared to be a sealed switch and I haven't taken it apart yet. I did switch it back and forth several times and the result remains unchanged.
It’s interesting that the hum is now gone after the C34 recap.
It’s also interesting that the meters don’t peg and you get a much lower amount of DC at the speaker terminals if you power up the unit with speaker switch off — and then turn the speaker switch on.
Why would it behave this way?
Does your 1968 unit have trim pots to adjust the DC offset?
