MC2505 catastrophe
In your above post --it looks like the white /black wire comes off the can and goes to what looks like chassis ground...
@Benz - I think your proposed wiring diagrams may be incorrect.
The marking on the outside of the C34 can (which I've outlined in yellow) appears to indicate the "nothing / dash" terminal (with the single white / black wire) is "Comm Pos." If so, that means this terminal is Common Positive.
Looking at the schematic below, I've highlighted C34 in red, and the half moon and triangle terminals appear to both be negative.
If my observations are correct, it appears to me that the positive leads of the new 470 uF and 220 uF axial capacitors would need to both connect with the single white / black "Comm Pos" wire. And the negative lead of the new 220 uF cap would connect to the white / green wire. And the negative lead of the new 470 uF cap would connect to the three purple wires.
We need to get some more Akers eyes on this. Am I right or wrong in this wiring analysis?
Also, I wouldn't use the center lug on the terminal strips as they are connected to the can bolts. By not using that center lug on the terminal strip you disarm the future (remote) chance the original can cap might degrade internally and a disconnected section shorts to the can (and thus to the center terminal strip lug). That's why I recommended Keystone 810 instead of 809. :)
I had assumed the black/white wire was negative as it goes to the chassis... through lack of knowledge I always thought ground was negative, but you're referring to "common positive", which is a new concept to me. Exactly why I'm posting here before connecting everything, so I greatly appreciate the input. And thanks for the point about not connecting anything to the center lugs, I hadn't thought about the possibility of the can shorting and causing a new issue. And here I was thinking a 3-post strip was a smart move!
That's how it was connected originally, from the "nothing" (center) terminal on the 34 can to chassis ground.
@Benz Can we get a better photo of the markings on the outside of the C34 can?
It looks like the stamped printing on the can indicates "COMM POS," but the printing is somewhat obscured in the below photo.
My interpretation is that Common Positive would mean that both of the two capacitors inside the original C34 can had their positive leads tied to the common lug with the white / black wire.
The MAC factory apparently changed the polarity of this can on later 2505 serial units. On my 1972 model, this can, relabeled C79, says "CAN NEG." But on your 1968 model, the can body is not connected, and the positive leads of both in C34 sections appears to be common and tied to one of the three terminal lugs (the unlabeled terminal noted with a dash on the side of the can). Your 1968 schematic also indicates C34 is part of a negative supply node.
Yes, can confirm that the markings show "COMM POS". Pic below (note that I removed the old yellowed jacket):
Thanks. Your C34 can markings indicate Common Positive, which I interpret as the lug with the white/black wire is connected internally to the positive leads of both sections (500 uF and 200 uF).
Also, the 188 numbering is the EIA manufacturer code for General Electric. And the 6819 numbering indicates this can was made the 19 week (May) of 1968.
Wonder if by any "lucky chance" there is a datasheet available for this cap
For Documentation etc ...
There might be. The part number stamped on top appears to be 066-093. Maybe McIntosh parts dept has a vintage GE data sheet in their archive?
Ah -- fortune cookie says " In future, must read previous posts before replies"
Progress --
Yea == Monk --
The part number 066-093 is, according to the SM, McIntosh part number... Would bet a dollar finding a datasheet would be hell..
Would the correct interpretation be "this is the positive terminal that is common to both capacitors found insinde the multi-can"?
The notations in the photo below are how I interpret your schematic and C34 can markings. I believe the positive leads of both sections (500 uF and 200 uF) are internally connected to the common positive terminal with the white and black wire.
Again, before you wire this up, we need to get more Akers eyes on this and determine if I am interpreting this correctly.
Ok, that is how I understand it now as well. Will await confirmation. Only difference being my layout will be a mirror image of what you're showing in your hand-written diagram given the location of existing wiring (will follow same connections).
Sounds good. Before you wire this up, I would recommend asking @Bob the Tech if my interpretation of the C34 can markings and your schematic is correct. I may be wrong! :)
@Celadon in the photo of your 1968 2505 below, note how Mr. DeWick soldered the positive leads of the two radial C34 replacement caps to the solder lugs which are directly connected to the chassis ground. Electrically, this is the same as connecting the black/white wire to the common positive of both C34 capacitors. DeWick's installation appears to confirm my interpretation that the C34 cap on the 1968 units have reversed polarity and common positive should be connected to ground as they are part of a negative supply node. I've noted below where it appears DeWick soldered the positive terminals of the replacement caps to ground.
Ah! To further substantiate, I can confirm that the 9300uF can (the one on the right in my pictures when viewed from the underside) has the positive terminal connected to that same ground post the black/white wire is connected to. I should have thought of that.
Thanks Monk --
Yes I thought to ask if any clearer photos of the underside would help but looks like you nailed that..
OK ---
I mentioned polarity, because when I first bought this amp -- I listened to it at theguys house for a while -- everything seemed ok.
Went home and pulled the bottom. One of the 2 caps you are replacing had been bypassed with an axial underneath -- Looking like it was ready to explode!
Following the lead of whoever had done THAT work, I ordered a couple replacements -- installed the same polarity as previous rework and same thing good for a short time and swell up again.
Do you have a photo of how the prior owner installed the C34 section replacement cap that was on the verge of exploding? Let's take a look at the picture and see if they put it in backwards!
Monk --
Unfortunately -- I do not, this was so many years, 2005, or so ago --
I do think it was the larger uf portion, and did speak with Digikey at the time, regarding the swelling, (like tech reps) but polarity was never mentioned... but none of this will prove helpful now.
Does the way that my unit is currently wired give any clues at all ?
I say don't be in a hurry for answers -- hopefully some of the older guys from the past will give a clue -- lots of guys here -- hopefully still here, that really knew their stuff -- and gave help.
Bob the Tech also confirmed, in a separate exchange, that the polarity is indeed as Monk indicated earlier, ie that the and middle post on the C34 cap is positive. So I should be good to go!
