MC2505 catastrophe
Very helpful, thanks! I noticed that the Vishay 470uF you suggest is 100v vs 75v for the original. That won't be an issue?
When replacing a capacitor, it's perfectly fine to increase the voltage rating of the capacitor by a moderate amount. You just don't want to use a lower voltage rated cap than the original.
In your case, the factory original capacitor was rated to withstand 75V, and the new Vishay cap has 25V more headroom and is rated to withstand 100V.
Ok, great thank you both for confirming. I will order the parts you suggested Monk, I took some measurements and I think I can make it work. I'll start there and order more parts later once the issue is resolved. They're shipping from Kitchener (Canada) which isn't too far from me so I should get them on Monday or Tuesday. EDIT: they're actually shipping from the US, but should still get them in a few days.
@Benz the reason I recommended that Vishay BC Components cap is it has an 8,000 hour lifespan at 125C and is automotive qualified. That means it is extremely robust and should outlast all of us. :)
For McIntosh, use the highest quality parts...
Thanks for posting that pic Celadon, It gives me a good indication how I would rewire if I go with separate 200uF and 500uF caps to replace C34.
I wouldn't recommend installing the two C34 under chassis caps the way DeWick appears to have done it in celadon's unit. DeWick apparently left one leg of that can in circuit as a terminal and tacked in a couple of caps elsewhere. If that original C34 can section still in circuit has leakage or shorts to the another disconnected can section or can common it can cause an issue.
I would leave the original C34 can bolted in place (for cosmetics) but have all wires disconnected from the can, keeping the 55 year old C34 out of circuit completely. Affix a Keystone 810 terminal strip under each of the two locking nuts of C34. Then solder the two Vishay BC axial caps to the two terminal strips, and migrate all wiring from the C34 can to the terminal strips directly below the old can. Because the two new caps are directly below the original can, you should be able to reuse all the original wiring without alteration.
Perfect, that's what I will plan to do then. I ordered the parts discussed yesterday, + C11-12 and C35-36. I will start with that (focusing on C34 first to make sure the issue is resolved). I will place another order subsequently for the remaining caps. Now the waiting, shipping will take a few days.
Cheers
I totally agree with Monk on this -- the axial vishays and terminal strips Monk had posted w/ pics, and part numbers would be a great/better implementation -- and much more to my liking as well.
C33 is available as an entire replacement manufactured by CE (there is a link a few pages back.)
And of course the proper big filter caps are indeed now available from McIntosh and as has been noted above, have been increased to 15000 uf.
Benz -- You can do this --Sounds like your plan is coming together nicely.
About the only things I think of at this point are:
Take lots of pics from lots of angles for your own reference before anything comes apart.
Do a component at a time.
Plan out your available real estate, and evaluate how you will implement the installation of the axials and term strips.
AND as mentioned way previously be certain you have the cap polarity correct.
Check and recheck -- your work.
Sometimes I will walk away for a few hours, or maybe even the next day check my implementation thoughts/ work done etc -- before moving forward.
Oh-- you had mentioned your skills w/ soldering -- do some practice soldering on an old meaningless item-- maybe a junky radio from a thrift store to hone up your skills a before you start on the beauty.
****Rereading the past few posts -- Monk has this lined out really nicely indeed-- following his suggestions will assist greatly :)
And -- thanks Monk, for the fine pics of your unit -- super clean looking for sure... *****
Staying tuned for up coming good news.....
Celadon
I really appreciate the advice Celadon, and am extremely thankful for all the assistance that has been extended thus far by everyone (special thanks to Monk). This is an amazing community. To be honest I was quite hesitant going into this but you've all given me the desire to forge ahead.
I'll remain optimistic as the story continues... now I just need my parts to arrive.
Cheers
Hi, yes C33 seems to be this one here: https://www.cedist.com/products/capacitor-ce-mfg-250-v-150808050-f
I've searched for the McIntosh big caps but couldn't find anything, perhaps I'm looking in the wrong place. Do you happen to have a link to the McIntosh replacement you are referring to?
Here is a pic of the CE cap, somethiing about them purchasing the tooling or whatever from I believe Mallory.
Yes --that's the CE cap I bought -- it was easiest to call and order, (don't forget the phenolic washer (middle item under accessories on the page you linked) don't know how many are required for your project but they are inexpensive and I would rather have all new :).
CE won't sell direct to you, but it seems they are part of tubesandmore/antique electronic supply.... "give us a call at 480-755-4712", says they ship to Canada....
Super nice helpful guy on the phone -- really fast shipping to me and reasonable all around - super nice people to deal with. Nice looking quality too.
The large filter caps --
Buy them direct from Mcintosh Labs, parts dept in NY...
You will be getting your checkbook out for those...
Hope that helps,
~C
Super, thanks again. I will contact Mac Labs next week to find out how much the big caps are.
I have read here that the McIntosh caps are old, like. 20 years old, you might want to ask what the date codes are on the capacitors before you pay a premium for these caps (I would).
Not that a 20-year old NOS cap is automatically bad but I would prefer new if I’m going through all of the work of replacing them.
Thats an interesting thought...
I have a pair installed on mine I am working on, wonder if I can see any numbers without pulling one... let me see, and report my findings.
Had to pull one to get the numbers -- Here they are:
Jeff are you able to decipher their manufacture date ?
Very good to know. I don't know that I would want to swap them if the replacements are that old, the original ones I have are still in spec... will definitely inquire when I call them.
Maybe someone can figure out the date code, they physically look like they are of recent manufacture--this pair was purchased maybe 2 years ago-- life has gotten in the way, and now am fired up about getting mine back into service.
I wonder what a difference the increase in capacitance will make....
