specialized
Member
I hope RonC would answer me.. How u compare MC452 to MC501 and to MC402?
What difference should we expect?
Thank u
Darko
Thank u
Darko
You cannot go wrong with any of themIt's that easy
Those are three very nice amps to compare!
Thanks,
Ron-C
That's a very nice answerBut i would feel even nicer if u describe a bit more comparing MC-452 with 402 and with 501.
I hope u would be nice enough to write nice description of those nice amps
Nice greeting
Darko
Aim for audition them and compare the sound with your own ears. Only you can tell what sounds good for you.
If you compare the amps, you have to be careful if they are cold. The MC452 has bias tracking which will mean the amp will sound about the same when it is cold as when warm. That is one nice thing about bias tracking, no warm up needed.If you do not know this, you could mislead yourself into thinking that differences between the amps, the older ones that need to warm, are greater than they may actually be. The MC501s and MC402 will need some period to warm to sound their best. Make sure to give the older models time to warm up if you want to do an even comparison. I see that the MC452 has a damping factor of greater than 40 and the MC501s are rated as greater than 100. Believe I read some where that anything over 100 is as good as you need? Not sure how much of a difference the dampening factor is. The MC501s produce more bass than the MC402. Is the higher dampening factor that it also has over the MC452 a clue that the same will hold true with this amp? I do not know.
That would be my guess. The MC501s, like all of the Mcintosh monoblocks, have bigger autoformers. There is also the potential for a larger power supply with a monoblock design. With stereo amps or multi-channels amps you can have two or more channels drawing power, in most designs from a single power supply. Of course with a mono there is only one channel drawing power. A few years back, I owned an amplifier that had the ability to both bias track and shut down channels from either 5 to just one. One thing that I noticed was the that amp sounded significantly better in stereo the less channels that were on. Not an apples to apples to comparison but I think the logic applies. Typically multi-channels amps do not sound as good as stereo amps and stereo amps not as good as monoblocks. That has just been my experience. The MC452 however may benefit from newer circuit designs and different parts that may not be so apparent that may bring it closer to the monoblocks. My guess is that it still has a shared power supply and smaller autoformers per channel.. From u'r post seem that MC452 is a bit of improvement compared to MC402 and that MC501 is still one class higher.. Or u dont agree with me?
Darko
I'll start out with a single 452, and then add a second with both running in mono if I need the extra 3db of power.
. I have decided to sell my MC501s and wait for the replacements.
I like the 'if your system is not that power hurry......' part. Guess I'm old school.Recently there are lots of used 501s on sales and you can get some real deals. If your system is not that power hungry, a pair of 501 can make you feel like in heaven. Why wait!? cdp.
