Jan, thanks for this great thread. My 2270 had some flakiness in
the pushbutton switches and I found that the contact resistance
was uneven and rather high.
I opened up a couple of the switches and cleaned them as per your
instructions. However, it took me a long time as one of tiny springs
flew away and I spent an hour searching for it. Then the little U shaped
metal piece popped out in the other switch and would not go back in,
but I finally managed to put both switches back together and working fine too!
I have a few tips to add from my experience cleaning my 2270 -
1) If the little spring behind the metal contact pops out, tie
a thread around it before attempting to fit it back, so it
won't fly out and disappear. Believe me, it can save you a few hours
After the spring is back in place, you can pull out the thread easily.
2) Hold the contact down with your finger while cleaning, so you
can prevent it coming out and losing the tiny spring.
3) For most of the pushbutton switches, you don't need to open them
to clean them.
There are a hole or two on the top of the switch. I found that injecting
Isopropyl Alcohol into these holes using a hypodermic syringe and
then operating the switch about 10 times fixes the contact issues.
I went from contact resistances of over 50 ohms to under a ohm with
this procedure.
4) There a few switches hidden under the volume and balance pots
in the 2270. To reach them, I first removed the pots from the front
panel , and then had to undo a couple of screws to remove a metal
shielding plate. The holes in the switches are now accessible, and
my syringe trick worked fine to clean them up.
There are also some switches under the selector switch, which
I could access and clean thanks to the syringe.
After cleaning all switches and the dubbing jacks, both channels are
working perfectly and the low volume on one channel issue is now fixed!
