Tube Radio
However a choke in the power supply can somewhat mitigate the power supply caps being limited by the rectifier tube given the choke has some DC resistance so long as the first filter cap is not over the max for the rectifier.
I don't know that the Edcor is significantly better to listen to. Its got a little more bass but its nothing you couldn't fill in with a small amount of subwoofer.
Another thing you can do though is bi-amping. Active crossover upstream of the amp and split it into highs and lows. Probably vertical bi-amping makes the most sense here, so one amp per channel. One is for the bass and the other for the highs on each side. Need speakers that can accept this sort of input. Its not going to make any more power but it might improve dynamics a bit.
I agree, try using the original output transformers first. I wound up leaving them in my 9303. They're probably the best OPT's Magnavox had made.Honestly I'd give a go to using the stock transformers first. They may surprise you with how
Wow, great thread! Finally made it through, tho I admit to just skimming some of it.
Been out of the game for a while; are the Z-565 clones unavailable? I picked up a really nice console with a 9302 amp; I’ll rebuild with the Z-565 if I can, if not I’ll use the Edcors with gadget’s circuit. But I would really prefer the Z-565.
Thanks for the tip on fresh outputs. It still has the original Magnavox stencil ‘West Germany’ EL84s; I haven’t tested them, but I imagine they’re pretty tired. The console is actually working - a rare find for me - but it does sound tired.I should mention it does better power with tubes that aren't worn out. I'd have to go back and measure it with the set in there now to get an exact number but its somewhere around 13 watts with a good set of Valvo vs a little under 10 with the tired old RCA tubes.
I actually just replaced the wafer sockets in it last weekend. One had broken so I did both, and the random top mount socket I had used for the cathode follower always annoyed me visually so now its got a proper set of old US manufacture bottom mount sockets that look like they belong there.
