I have backed up everything on an external hard drive and then transferred it all back to a new one... It took a lot of time though....
Spider-pig, Spider-pig, does what no other spider pig does...
Ivan is the help line.
Remove the HDD, ghost it to 1.5tb drive, reinsert 1.5 tb drive, invent MS1.5K.
I have norton ghost 2003, I plan on ghosting the MS300 hard drive to a 750 gb hard drive. I will use the cloning feature. I will then save the 300 gb drive as a backup for the MS300 operating system.
That is what I figured, ghosting it would be much faster than any other way.
I have had my MS750 open for the fan upgrade. The hard drive is not SATA.
I'm not computer technician, but just a thought. If you swap a hard drive in a computer, the BIOS has to be reconfigured to recognize the new drive, its size, sectors, etc. It would seem to me that just swapping a 1.5TB hard drive in place of a 750GB hard drive would require a BIOS upgrade for the MS750 (or MS300) to recognize the hard drive before it will operate.
Dan....Thanks for searching for that pic :thmbsp: ..
side note...since you got that Sonos hooked up to your MS750.....are you using the Sonos Controller to access your library or the monitor I saw in one of your pics?:scratch2:
Yes, you definitely can access the FLAC files on a networked MS300/750 via a Sonos. Dan is just saying he doesn't choose to access the FLAC files on his MS750 when he is listening to his main system where the MS750 is because he prefers the sound of the MS750 outputting its FLAC files to the MCD500.Dan,
You access FLAC files with your Sonos that are on a hard drive associated with our computer right? You can't access the FLAC files that are on the MS750 with the Sonos right?
Just trying to figure this all out..
Thanks,
Michael
