So these things keep falling into my lap these days, but this one is a little different. First off it came with the first Panloc plate that I've seen, so it took me a moment to figure out how to get it off the unit.
Untitled by analog addict, on Flickr
Once I took a look at it I noticed it had flat instead of peaked tops on the metal structures running along the right side. Both of my units have the peaked tops, which I've been led to believe is a hallmark of the last of the Z units. Is this an earlier Z iteration or not a Z at all?
Obviously someone been inside, so I had no idea what to expect when I opened it up.
Here's the serial number...
And another wrinkle
So after some play testing during which not only does it sound fine, it may sound better than my unit. Seems to have more gain as well. Controls are also without any noticeable scratchiness. Tubes appear to all be OEM Telefunken. Finally made some room on my bench and took the bottom off. Here's what I found...
These are obviously not OEM. Anyone have a guess on how old they are. I've a mind not to replace them. The selenium rectifier and top hat diodes are still in place, but I get the vague feeling that it's not quite the same underneath as my previous units.
Thoughts? Comments? Suggestions? The plan is to replace the multicap cans, any remaining electrolytics, the top hat diodes, and the selenium rectifier. Anything else need replacing? Will it need a dropping resistor with a modern diode bridge in the HV PS? I don't believe I've used one in my previous restores with the understanding that the voltages will be a little higher, but not out of reason for a functioning unit. Lastly, the power transformer gets pretty warm, but I can leave my hand on it, and not get uncomfortable. Should I worry?
Untitled by analog addict, on FlickrOnce I took a look at it I noticed it had flat instead of peaked tops on the metal structures running along the right side. Both of my units have the peaked tops, which I've been led to believe is a hallmark of the last of the Z units. Is this an earlier Z iteration or not a Z at all?
Untitled by analog addict, on FlickrObviously someone been inside, so I had no idea what to expect when I opened it up.
Untitled by analog addict, on FlickrHere's the serial number...
Untitled by analog addict, on FlickrAnd another wrinkle
Untitled by analog addict, on FlickrSo after some play testing during which not only does it sound fine, it may sound better than my unit. Seems to have more gain as well. Controls are also without any noticeable scratchiness. Tubes appear to all be OEM Telefunken. Finally made some room on my bench and took the bottom off. Here's what I found...
Untitled by analog addict, on FlickrThese are obviously not OEM. Anyone have a guess on how old they are. I've a mind not to replace them. The selenium rectifier and top hat diodes are still in place, but I get the vague feeling that it's not quite the same underneath as my previous units.
Untitled by analog addict, on FlickrThoughts? Comments? Suggestions? The plan is to replace the multicap cans, any remaining electrolytics, the top hat diodes, and the selenium rectifier. Anything else need replacing? Will it need a dropping resistor with a modern diode bridge in the HV PS? I don't believe I've used one in my previous restores with the understanding that the voltages will be a little higher, but not out of reason for a functioning unit. Lastly, the power transformer gets pretty warm, but I can leave my hand on it, and not get uncomfortable. Should I worry?
Untitled
Untitled
Untitled
Untitled
Untitled
CIMG7452
Untitled
Untitled
Untitled
Untitled
Untitled
