MX-110 model identification and restore...
Make sure you're set to FM MPX, with no antenna connected, and the tuning dial all the way to the left. And, you may need to go a little bigger too.
Dave
No change with the current method and 100 and 200 ohm resistors. Am I just being dumb since right now I still have the regular ground from the negative end of the bridge connected? I think the light bulb just came on and I'm supposed to lift the original ground so I can jumper a resistor in between the negative end of the rectifier and ground. So leaving the original ground in place means I'm just pissing in the wind with any resistance I try, correct?
There ya go. The ground end of the negative side diodes need to be lifted from ground, and the resistance placed between the diodes and ground......
Dave
These hybrid pieces make my head hurt. Give me a good old fashioned tube rectifier every time.
Anyway, I worked up from 47ohms to 100 to 200 to 220 to finally a 270ohm/10W resistor. Here are the measurements....
At the 225VDC point, I get 227VDC,
at the 170 point, I get 183
at the 150 point I get 161
and at pin 1 of V8, I get 100 VDC
I don't think I want to mess with it any more. Of note, the resistor gets hot. I can only lay my finger on it for a moment. I'll have to dig up my IR thermometer and see exactly how hot. Is this OK? Luckily, it rests right below some of the vent holes in the chassis, but it is also close to the filtering caps for the PS...
Also, when I turn it on, I get a voltage surge at the 225VDC point up to 335 VDC, then it falls off to the above values. Not to beat the thermistor thing to death, but at least theoretically, doesn't a thermistor help with this in rush surge? I'm assuming the McIntosh engineers had this type of response in mind, or alternatively, the change from selenium to silicon has altered the voltage response in more than just a smaller voltage drop. I'm curious to learn more...
Lastly, adding the resistor on the negative side of the bridge does what exactly? Just adds load on the negative side that doesn't alter the characteristics on the positive side except the added load causes the desired voltage drop across the whole circuit? I'm used to seeing these high voltage center tap winding going to ground rather than putting out 83V, so this is definitely an opportunity for me to learn something new as well. Can I assume this was a specially designed PT by Mc?
The MX-110 uses a combination full wave bridge rectifier in conjunction with a conventional full wave rectifier circuit. The bridge rectifier produces twice the voltage output that the conventional full wave rectifier does, and powers the audio circuits and local oscillator. The conventional full wave rectifier power the remainder of the tuner circuits, the MPX circuits, and provides the positive heater bias for the DC powered heaters.
Within the four diodes making up the bridge rectifier, D401 and D402 strictly serve the positive output of the bridge rectifier. But D403 and D404 make up not only the negative side of the bridge, but also serve as the rectifiers for the conventional full wave rectifier circuit. The conventional full wave rectifier may not be that apparent to see because it is typically configured with the center tap of HV winding grounded, with the positive side taken from two diodes -- one connected to each end of the HV winding (tube or SS). In this case however, the polarity of the two diodes that serve in the conventional full wave circuit are "turned around backwards" from how they would normally appear, because they have to be to provide the negative output of the bridge rectifier circuit. What to do? Mac simply provided a CT to the HV winding that then becomes the positive output of the conventional full wave rectifier circuit, so that the two diodes D403 and D404 are really doing double duty. But here is the point: because they represent the negative output of both of these supplies, it means that any resistance placed in series between these two diodes and ground will lower (proportionately) the output of both the bridge and conventional full wave rectifier circuits simultaneously.
As a result, be sure to check the B+ voltages to the tuner circuit as well. Those circuits draw by far the most current in the unit, so any adjustment should be based on the voltage going to it. If you find that after adjustment that the voltage to the audio circuits is still higher than you would like, then you will need to place an additional resistance between the output of the positive rectifiers, and the first filter cap. Any resistance added there will only affect the voltage supplied to the audio circuits. I suspect that if you have been making the adjustment based on the audio circuit voltages, then the tuner voltages will now possibly be too low.
If you want to go the thermistor route, watch that the AC and DC heater voltages don't drop too low as a thermistor will affect all voltages in the unit. As for the turn on surge voltage, the conversion to silicon rectifiers definitely makes for a higher surge voltage. A properly sized 1A CL device for this unit will usually only curtail that slightly (but only slightly) -- but also make the surge last longer because the heaters are warming up more slowly. As long as the filter caps can handle the surge voltage wise, the surge is really of little issue.
The rectifier design is not anything that Mac developed, but is a configuration that became possible on a practical level due to the development of appropriate SS rectifiers (selenium or silicon). The configuration could be populated with vacuum tube rectifiers as well. But then you would also need the attending heater windings -- three separate heater windings -- with the tubes employed being a convention full wave type tube, and two separate half wave rectifier tubes (think damper tubes). From a production cost standpoint, this would be prohibitive in a product like the MX-110, but becomes very practical if not desirable when non-thermonic rectifiers are used.
Mac used the exact same approach in the original MC275, using a bridge rectifier circuit to provide the B+ to all of the amplifier tubes except the 12AZ7 cathode follower driver tube in each channel. The B+ for that tube was derived from a center tap on the HV winding, in the exact same way that the tuner circuits are powered from the CT on the HV winding in the MX-110.
Dave
Thanks for the additional info Dave. I learn something new every day in this field. I'm going to skip the thermistor, both for the reasons given and because the location I would normally want to place it in is now occupied by new caps.
Getting back to the measurements, V4 measures 81 and 85 VDC at pins 5 and 6, but the tuner seems to be working properly. At least it is pulling in a local station and sounds full and rich. Is there a down side to not messing with it?
Measuring at C116D, I get 83 VDC exactly. OTOH, on pin 6 of V8, I get 18 VDC while the schematic says I should be getting 88VDC.
Thoughts?
Any other crucial locations that should be measured?
The voltages measurements you obtained at V4 are about 10% low, which is not of any real concern as long as you were measuring them under the right conditions. That is, no antenna, with the tuning dial indicator tuned all the way to the left (lowest frequency), and the muting switch turned off. Under this condition, the tuner section will draw maximum current, and is the condition under which the voltage indications on the schematic were made. This is a matter of some importance, as under this condition, any AVC bias voltage developed by V6 for application to the RF and 1st IF amplifier stages is all but gone, so these stages will then be drawing maximum current to provide maximum amplification. The change in current flow from no signal (i.e., no station) to strong signal conditions in the tuner section can vary quite significantly. Therefore, when checking specifically tuner voltages, it is important to set the conditions of the tuner up correctly so that an accurately comparison can be made. This is true whether you're working on a McIntosh MX-110, or a vintage Sears AM-FM table radio.
The voltage indicated at pin 6 of V8 on the schematic is likely a misprint. This section of V8 serves as the muting control tube, the design of which changed only insignificantly throughout the various versions of the MX-110. Earlier schematics show 37 volts at this point, while I typically measure about 30 volts, with the actual indication very dependent on the particular tube installed at the V8 location, and even the setting of the muting sensitivity control. As long as the unit is muting satisfactorily on FM tuning functions when the feature is engaged, and particularly when the unit is set to any non-FM input setting (no background bleeding of the FM signal if tuned to a station), then I would disregard your voltage reading at pin 6 versus that shown on your schematic. In many receivers (Fisher, Scott, etc.), the design includes killing the FM section when not selected by literally switching off the B+ voltage to the tuner circuits so that no bleed through can happen with other input signals. Mac took a different route, and simply forces the tuner into full mute (even if tuned to a very strong station) so that no bleeding can occur on non-FM input settings.
Dave
Thanks Dave. I was going to ask you about the specified conditions w.r.t. the tuner, but you beat me to it. I believe I had it set up properly, but I will double check. The heat from the resistor between the rectifier and ground is an expected condition? Since I have a 10 watter in there, I’m confident it can handle the current but again, I thought I’d ask before calling it finished....
Yes, it will run very warm as it is not only passing the DC current as drawn by all the various circuits of the MX-110, but it is also passing the significant AC ripple current drawn by the first filter caps of the two high voltage rectifier circuits (C114 and 116A). Ripple currents can run as high as 80% of the steady state DC current drawn which means that the resistor is passing both DC and AC current. Ripple current contributes significantly to transformer heating which is why placing a dropping resistor at this particular point is so advantageous: In addition to dropping the steady state DC voltage as necessary, it also limits the surge from these caps at turn on, and limits the steady state ripple current as well by mimicking the inherent drop that was a characteristic of the original selenium rectifiers when new. A 10 watt resistor is plenty large, with a 5 watt device normally filling the bill perfectly both in terms of physical size, and dissipating rating.
Dave
Well, the voltages at V4 were about 1 volt different, so I figured it was good to go.
Untitled by analog addict, on Flickr
Buttoned it up, hooked it up to my PSE 45 amp running Khorns, and it sounds great.
Just one little problem. The FM stereo light stopped lighting up. Looking back at the schematic, that's V11 and sigh...what looks like a transistor, MA 113...
Is the unit still in fact producing good FM MPX stereo performance, with well defined channel separation (obviously as observed on material you are familiar with to know how the stereo was recorded)? Unless you have a MPX generator, it's usually best to find an oldies station or vintage rock station to determine this as recordings made back in the day often threw one or some instruments or voices completely into one channel or the other to produce a rather dramatic stereo effect. Today, that's rarely done anymore, with stereo merely contributing an ambience effect to the overall sound that is otherwise not possible with a mono recording.
Make sure the bulb didn't burn out or the bulb socket isn't just dirty. The bulbs rarely go out, but that possibility needs to be at least checked to eliminate it (or not) from the list of possibilities.
Dave
A quick note, as part of my repair process, I pulled all the OEM tubes and used a set of testers out of my stock. After I took the first pic from the previous reply, I reattached the bottom, flipped it over and put the OEM tubes back in. I may need to swap out the 6U8 at V11 for chuckles and grins...the bulb was working just before I put the bottom back on
Well, looks like the bulb is out after all. Tube change made no difference for some odd reason. So what is the standard for a #1850 bulb change these days?
As far as I can tell, these are the specs....5VDC 0.09A (0.45W) T3-1/4 glass bulb with BA9 bayonet base. Maximum length of 1.22in, 13/32" (10mm) diameter.
I have a box of OEM lamps in the supply, but none of these. Are there any potential more common substitutes?
I'd also be tempted to look at an LED substitute if available. Thoughts?
Stick with the original bulb. It's designed current flow in part biases the control transistor and therefore determines when the lamp comes on. An LED won't do that.
Dave
Got the bulbs and was surprised to see they are made in Taiwan rather than the PRC. Rebulbed and singing like a guilty choirboy. Going home to it's happy owner...
What tube preceded the MX110 Z series 6D10 tube position in the previous MX110 series X preamp? I can't seem to find the correct schematic for the x series.
Unfortunately the schematic in the URL link is for the "M" series. Here is a screenshot of the tube in question in the "X" series. The tube socket identification as seen is difficult to discern. It is in the same position as the 6D10 in "z" series. Again the question: what is this tube model number?
Looks likw the chassis denotes it as a 6AB4 which jives, thats a VHF/UHF triode
Thanks that's what I thought, but the VHF/UHF triode info is interesting to know. I would like the MX110x schematic if I could be directed to download it.
