karsavuran
I am basically following the work done you did but apparently I am missing something here. Two parallel 0.1 uF should be 0.2, why did you used 0.47 uF?Used 0.47uF Solens in place of the paralleled 0.1uF disc caps mostly because of size considerations.
Is there any advantage or disadvantage of using two caps in parallel. I am using Panasonic caps so I do not have space problem. So should I go with 2x0.1uF or 0.22uf or 0.47uf in these two places?
