braxus
FeCr Type III
Realizing I dont really need another tape deck (I already have too many- yes I have a problem), and the fact the market today will probably never get back into cassettes (not like Reel to reel decks that are making a comeback) and make such a deck, I would trade the majority of them in for a dream deck like this one. I was milling around remembering the days when cassettes were popular. Had CD-R not killed the format for mainstream use, I wondered what kind of ultimate cassette deck could be made with what technology we have today. I came up with a Sony/Aiwa/Tandberg/Nakamichi/Revox hybrid. I'd love to hire the techs that worked on the best Tandberg (3014A), Nak (ZX-9), Aiwa (S9000), and Revox decks and get them to design this new deck. If I had the chance to design a high end deck for professional and consumer use today, here's what I'd ask for:
-High quality build with pro grade parts inside.
-3 choices of output stages- A: Solid state. B: Tubes in output stage. C. Digital output via firewire with choice of 24 bit 384/ 192khz or 1 bit DSD
-4 motor dual capstan with pressure pad lifter (capstans able to handle faster speeds)
-3 choices of speeds- A. 1 7/8 IPS. B. 3.75 IPS. C. 7.5 IPS.
-fast forward and rewind speed brakes to slow down cassette before stop
-real time tape counter with memory point programable
-4 choices of noise reduction with HX-Pro (all usable at all speeds) plus OFF (no noise reduction)- A. Dolby B. B. Dolby C. C. Dolby S. D. DBX type 2
-seperated sections for power, input, and output with honeycomb copper plated chassis (aka Pioneer CT93 and Sony TC-K555ESJ), center cassette position (Sony TC-K909ES), and vibration reducing wood base (Aiwa XK-S9000).
-best material for heads for sound quality (aka Naks), but also capable of very high input/output levels
-6N pure copper wiring inside
-3 head system with seperated record and playback heads (aka Naks)
-cassette shell damping clamp (aka Sony and Aiwa decks)
-digital display VU meters from -40 to +20 db with *post-equalized* metering and 0 dB corresponds to a 250 nanoweber/meter (nwb/m) flux level
-input direct mode bypassing balance control and other sections
-seperate fine bias control for left and right channels (aka Naks and Teacs)
-record EQ setting plus record level for Dolby/DBX
-auto tape bias/level control/head alignment for recording with 4 test tone generator (aka Pioneer CT-93)
-record mode that turns off erase head for better signal to noise ratio on virgin tapes (aka Aiwa XK-S9000)
-balanced signal paths (aka Rotel), common ground paths (aka Luxman), and dual mono audio board (Sony TC-KA7ES)
-auto azimuth adjust(aka Naks)
-computer controlled transport system for very high head contact capability and accuracy, plus reduced head wear (aka Naks)
-speed adjust trim for slower or faster playback (pitch like control) with on-off bypass switch
-shielded sections between stages
-external isolated twin R core power transformers (aka Aiwa XK-S9000/ Excelia XK-009 and Sony TC-KA7ES)
-quartz locked direct drive with low wow and flutter
-transport safe enough to use with 120 minute length cassettes
-15hz to 27khz +-3DB at -10db level normal speed, 20hz to 27khz +-0db at -10db level 7 IPS mode
-flat frequency response from 20-20khz +1/-2db at all speeds at 0db level
-65 to 70db SNR without noise reduction
-XLR mike inputs with phanton power
-switch for mike or line level inputs via RCA connections
-choice of RCA or XLR output jacks (connected to the two optional analog output stages)
-external battery pack attachment for use on location
-internal power conditioner
-less IC circuits and more discrete circuitry
Did I miss anything? This deck would have to be on par and beat the performance and sound quality of the best decks including the Tandberg 3014A and the Nak ZX-9. Also to be released with this deck are the return of a modified Metal cassette designed to be used in this deck at high speeds. This deck would be for people who want reel to reel sound quality on cassettes that are still available, plus to kill by offering better then CD sound quality.
Target sales: To prosumers to convert their tape collections to digital, people who need a high end analog recording system with still available cassettes, or people who just want the best freakin' deck possible to get.
Price-$5000 or so
I'd suspect at that price point they could sell enough to merit it, especially since there are still die hard analog users out there with decks that you cannot get parts for anymore. And with the fact many burned CDs dying within a few years of being made, and that cassettes have better longevity, then it might be a good time for a return of one good deck out there.
My second option would be to produce a 1/4 inch reel to reel deck with cassette deck like features. Many reel to reel decks never used technology put into cassettes and this would be a good place to do this. A reel to reel deck with features I'd like is: 7.5 and 15 IPS, Dolby S, 1/4 track playback, 1/2 track play and record, bias fine with calibration mode, metal tape feature to use digital reel to reel tapes on, high headroom electronics, XLR mike inputs with phantom power, 3 choices of outputs similar to above list (tube stage, solid state, digital output (PCM and DSD), amd pitch control.
Price-$5000 or so
I have my checkbook ready......:yes:
