Back in the mid 80s, I worked at Stereolab in Cambridge and used to repair a lot of high end decks. There were others that could obtain 20 khz recording at 0 db. The HK CD-491 could and i think the Onkyo TA-2080 was another. Interestingly, the most expensive machines were the super fancy Tandbergs, they couldn't come close and would roll off at 16 khz. The 3 head JVC decks such as the KDA-77 also had superior high frequency headroom and were good to 18KHz at 0. The JVC used the Super ANRS noise reduction that preceded Dolby C by several years and really was superb in it's ability to prevent high frequency tape saturation. I own a Nakamichi CR-3 and it also will do 20khz at 0. They can be found super cheap. My favorite overall deck was the Nak 680zx. That machine could do 22khz at 0. Even at half speed it was ruler flat to 15hkz and could outperform many of it's competition. My tape of choice was the Maxell UDXL2. To obtain these numbers the tape needed to be brand new or nearly so. Metal tapes provided even better performance but the quality was so good with the xl2 I felt metal was overkill for most purposes.
This is simply way out of line statements with absolutely no truth left.
I'm sorry.
I find you unreliable.
Did you sweep the floors at that place you worked back then?
I have TCD 910 & 440A and the Revox B710.
Chose the 910 instead of all the Nak's that I tested.
Dragon, CR7, ZXL1000 etc. etc.
I had a big bunch of other tape recorders with some Nak's, Studer, Tandberg 3014's & 330's/310's, JVC, B&O, Sony, Teac's etc. etc. in between.
Always the best of the brands as first pick.
Never had a machine measuring better than the 910.
Went up to 23.200 Hz at 0dB measured and witnessed.
Pick the right tape, dude, instead of putting a worn down Fe tape in the Tandberg and Me tapes in other machines when you do the job.
Make sure you don't work on a worn down 24/7/365 radio studio machine from the early days.
Don't use NR when measuring Freq's.
Don't use NR at all but pick good tapes instead IRL.
Never heard a machine sounding better than the 910.
It outperforms all Nak's.
It outperforms all.
910/911 , 3014/3014A and the 3004 are alle better sounding than the 440A or any in the 3xx series.
They sound better, they measure better and have better drivetrain.
Think before you talk.
I wrote more detailed about testing of the best of Tandberg, Revox and Nakamichi up against each other earlier on this forum.
But don't forget the better obtainable sound in good R2R's.
"dolph"
