My Dream Cassette Deck
Status
Not open for further replies.
I looked up Dolby C in Wikipedia, and all it says is:
"Dolby C provides up to 20 dB noise reduction in the high frequency range, but the resulting recordings sound much worse when played back on equipment that does not have Dolby C noise reduction. Some of this harshness can be mitigated by using Dolby B on playback. It utilises anti-saturation and spectral skewing techniques."
Later: Ok, I found the answer at http://www.dolby.com/assets/pdf/tech_library/212_Dolby_B,_C_and_S_Noise_Reduction_Systems.pdf , pages 10 and 11. Recording 20kHz at 0VU, the tape is only seeing about -10 or -11VU, which explains the extended high end. In fact, at 10kHz, where cassette tape output consistency will be quite bad compared to the lower frequencies, there's a 2:1 compression ratio over a 55dB range. So yes, there's definitely a trade-off.
wil816 said:
I am familiar with spectrum analyzers. Using pink noise and a spectrum analyzer does not give distortion information. And I should have clarified that I did not mean the people doing the testing reduced the bias, but that apparently this one of the things Dolby C does, constantly adjusting the bias based on the program material. That's not all bad, but I'm very suspicious of anything that appears to give you something for nothing. But as I said earlier, the Dolby designers may have concluded that such extended frequency response at high record levels is seldom needed for more than a fraction of a second at a time for something like a cymbal crash, and that more distortion under those circumstances is more acceptable than a cymbal that sounds more like a toilet flushing because its sizzle is gone.
Another thing Dolby C apparently does is some companding, and not just around a lower threshold like Dolby B does. I used dbx for awhile on cassettes, and although the improved dynamic range is wonderful, the fact that it accentuates the cassettes' output inconsistency drove me nuts. Any little variation, even if not really enough to call it a dropout, became objectionable.
You have got a number of your facts rather mixed up here. Repeat after me: Dolby C never, Ever, EVER adjusts the bias! Period! You are just plain 100% incorrect about this. It is just a dynamically applies an equalization curve to adjusts the frequency spectrum of the signal in a manner extremy similar to how Dolby B does. At 0dB, and above, dolby B theoretically does nothing. At around -20db or so, it provides you 10 db of boost above about 1kHz durring recording, and 10dB of mirrored cut durring playback. In-between, it processes something less than 10dB of boost/cut.
Dobly C merely does more of the same, except that is does a 20dB boost/cut instead. Furthermore it "skews" its boost to the very HF in the exact opposite direction of the direction of the rest of the signal. So at 0dB, where dolby B is doing nothing, dolby C actually cuts the extreme highs (above about 15kHz) durring recording, and then boosts then again durring playback (the exact opposite of what it normally does). This "skewing" efffect keeps the tape from saturating at the very high frequencies, and provides a little more headroom. This is one of the reasons why, when properly calibrated, a Dolby C recording doesn't tend to sound "dull" the same way that Dolby B does. Now if improperly calibrated (as unfortunately a great many decks are), Dolby C can cause dulling too. But that is due to an effect known as "Dolby mistracking".
Technically, all noise reduction schemes are considered to be "companders" of one sort or another, and this includes Dolby B. But neither Dolby B nor C is a compander in the same sense of the word as is DBX. DBX is a 2:1 linear compander which applies the same amoun of compresion and de-compression at all frequencies and levels. Dolby is a highly non-linear compander, because it boosts/cuts only certain frequency ranges, and it does so to differing degrees at different levels.
So while the Dolby NRs (this includes Dolby A, B C, S, and SR) can techically be consider a companders becuase they do non-linearly compress/decompress certain frequency ranges, they are all COMPLETELY different animals than are any of the versions of DBX! DBX by contrast, can certainly be considered a compander in every sense of the word.
Where I suspect you amy have gotten thinking that Dolby effects bias is by a completely unrelated technology, which is called Dolby HXPro. HXPro does dynamically vary the bias to create more HF headroom. But HXPro is NOT Dolby NR, it is not part of Dolby NR, and it has no relationship to Dolby NR, other than that this technology was also licenced by Dolby Laboratorties! Infact a great many Dolby C tape decks were made which completely lacked HXPro.
Now, let met state yet again, since you seem to have trouble grasping this fact: Dolby HXPro has never been included inside of any Nakamichi ever built! Therefore, no dynamic bias tweaking is happening with these machines, no matter how suspicious you may be about this. Have I explained this well enough this time? I hope that I'm typing slowly enough for you...
But hey, don't listen to me! :no: I'm just some guy who merely has a degree in Electrical Engineering, has serviced and calibrated tape decks as a hobby for 20 years, and who has been an avid tape recording enthusiast for over 25 years (durring which time I have followed with great interest all of these technologies closely) So what the heck should I know about this stuff anyway?!? :stupid:
Now if your opinion is that all NR is bad because of getting something for nothing, then you are free to have that opinion. Many here will infact completely agree with those sentiments. But please get your facts straight about how these things work, ok?
Well I have to admit that as I was working on my two portable Marantz cassette decks, I kept thinking that it looked like all it would take to run them at 3.75 is an new motor pulley.
And then I wondered what it would take to convert them to 2 track (one way) seems like R2R stereo heads might work. Look at it this way if you are recording live you are not going to pull out the cassette and flip it around anyway, it takes too long, you would just swap out another one. So there really would be no loss there. And, I would not recommend the portables for copying CD's and LP's anyway.
Oh well, first comes some better quaility mic's. But I guess once a hot rodder, always a hot rodder, no matter what one is working on. Almost anything can be souped up a bit.
Actually, different tape speeds also require different record and playback equalization curves also (well, if you care about getting anything close to flat FR at least), it is not simply a matter of motor speed.
Also, even if you could manage to cram an open reel tape head inside of a cassette (FYI - They are too wide), you would still have trouble because open reel lays the tracks-out very differently from cassette. Stereo channels are split between tracks 1 & 3, FWD and 2 & 4,ReV wherase on cassette they are split between 1&2, FWD and 3&4, REV.
I you want to expemiment with such a fantasy format, just buy yourself an Elcaset deck instead. They did most of what you are suggesting, except that they used HUGE cassette tapes, and actually sounded really good. :thmbsp:
goldear said:
Okay Mr. Skeptic, here you go... :D
Impressive decks, looks like Nak got it right just in time for it to be irrelevant. Have to admit that I lost interest in the format in the mid-80's, and even when I was in the market I didn't even look at these decks for the simple reason that I could have never afforded one. It was a stretch for me to buy a Teac V-970X, and for me it took all the fun out of making a recording since they all ended up sounding great no matter what I did at the controls (I had a mid-line Teac A-400 for years before the V-970X, and it was fussy as hell to get a good recording, but I loved doing it).
Not sure why you're down on Dolby HX...it addresses a real problem with cassette technology. DBX too worked well on high-end decks with good tape...used it from time to time and it worked like a champ. But Dolby C was the system of choice.
Nowadays, the 970X pretty much sits and collects dust. If I had a Nak, it'd probably be doing the same thing. :boring:
You have misunderstood me. Actually I'm not down on either Dolby HXPro, or DBX. :no: I think that HXPro was one of the greatest technologies to ever come along for all of the other cassette deck manufacturers. It brought their HF headroom performance substantially closer to that of Nakamichi. :yes: I only said that Nakamichi didn't need it like the others did, but I have no issue with HXPro. I have a Kyocera cassette Deck with HX Pro that I think is second only to my Dragon.
My strong comments about Nak not using HX were in relation to some bizaare posts claiming that the Nakamichi must have been dynamically modifying the bias to get that performance, which was simply completely mistaken (this is basically what HX Pro does, and I was making the point that Nak didn't use it).
I will sometimes use DBX with my reel to reels. And I have tried it on cassette as well. But I recognise its limitations, as I do with Dolby C as well. My problem is that so many people are so down on Dolby C, simply becuase they have never heard it calibrated properly. When this is done, it can be a surprisngly good sounding noise reduction system. :thmbsp:
Goldear, I must say, I was a bit entertained by how worked-up you got yourself. One of your pdf's seemed to imply changing the bias on the fly, but it was referring to something else, and I already said that I found the scoop on Dolby C on Dolby's website.
If you're an EE and have worked so much with cassette recorders, I'm sure you have seen on an oscilloscope how a cassette's output of a pure tone at high frequencies is inconsistent, not solid like an open-reel machine's output is at the same frequencies. Specifications typically don't show this. Although we don't listen to pure tones for pleasure, they do make it easier to see the problems that plague us in practical usage. These small variations that are so much more of an issue on cassettes are the reasons I mostly quit using dbx on cassettes. What I see now about Dolby C on their website is that it has that same 2:1 compression and expansion ratio in the highs, which is why I can't get excited about it.
I am an EE. And I only ever brought this up point after your spiel about working as a Tech at Teac and all clearly trying to make yourself sound more credible. And then you say that you have only been doing this for a short time. Ok, which is it? Years of working as a Tech on analog recorders, or just a few month of new found interest? :headscrat
Anyway, I'll fully admit this thread has raised my dander a bit. And I appologize if my responses have gotten a little overly heated. I truly enjoy passing along my very considerable knowledge about audio to those who are interested in learning. And I do so freely becuase of my love for this subject. I'm just extremely frustrated that all of the evidence that I have presented to support my initial position about some select Naks having such impressive 0dB FR seems to have just gone right in one of your ears and out the other, folowed by nearly everything else that I have attempted to clarify for you seemingly being completely ignored too. :sigh:
You are correct, regarding the fact HF sine-wave performance on a cassette decks seriously stinks. Although in my experience, its actually not all that fantastic on most reel to reel machines either; but clearly it is much better than on cassettes. The jitter in the waveform, and the constantly shifting phase and distortion make it very challenging to adjust any recorder's azimuth perfectly.
However, your facts are still somewhat mixed-up with regards to Dolby's operation. No such "2:1 compression" ocurrs inside the Dolby system. :no: It is just a non-linearly shifting equalization curve that boost the mids and lower highs by up to as much as 20 dB durring recording and then inversely cuts them proportionately on playback. That is not the same as 2:1 compression. That is 20dB of upward mid to high frequency compression at low recording levels, and 0dB of mid frequency compression from a VU level of 0dB and above. In between the amount of upward compression in Dolby varys greatly, between 0 db, to as much as 20dB. Thus it is not 2:1 as you keep stating. Dolbys process is inherently non-linear. The 2:1 differential compression that DBX uses is by defintion LINEAR compression. That is why Dolby Requires careful level calibration, and DBX does not.
But you are correct about the fact Dolby C does exagerate the sensitivity to drop-outs. But so will Dolby B, just siginificantly less-so than will Dolby C. But again, this does not equate to 2:1 compression. There are many different forms of compression, and Dolbys particular schemes all have nothing at all to do with any form of 2:1 linear compression. That was DBX's claim to fame, not Dolbys.
I don't care if you decide never to use any sort of noise reduction. But I do care when you continually mistate how it fundametally operates due to a flawed understanding of the sytem. Its great that you are attemping to learn. I applaud your efforts. But I am attempting to set the record straight when you state something as fact that is clearly incorrect.
The technical operation of how Dolby works is a factual matter. It is not opinion. And I have been attemping very hard to help you get your facts straight.
Now, whether you think that Dolby is fantastic, or that it sucks is just an opinion, and that is an entirely different story. That is subjective, and for that there is no right or wrong answer. Now I may disagree with your opinion of the merrits of Dolby NR. But my opinion of its merrit is just an opinion as well, and is not any more or less valid than anybody else's.
Yah, I realise that. The tape heads were a pure fantasy thought. Actually the whole thing is, if I could afford to do all that I would just buy something a lot better to start with.
Actually I am just having fun learning new skills. It turns out to be quite easy to copy the cassette into the laptop, edit the sound, and either copy it back to another cassette, or burn it to a CD. Now if only it was as easy to decide which mic's to buy on my budget :D
Thanks for your reply,
HI Jim (goldenear),
Sorry but I must disagree with your 0db statements if I correctly understand them. As far as I know, all Nak's record/play response were specified at -20db. If you have other information it will be news to me.
Even if I'm right about -20db levels, that is still damn impressive performance matched by few if any other manufacturers. I have verified this in my repair shop doing Nak calibrations. The spec is definitely real. Actually, on some Nak's the high freqency extends to 22kHz (Dragon, CR-7A, 680 series, and others)!! Not bad for crummy ol' cassetts. :thmbsp:
Sparky
Karma16 said:
HI Jim (goldenear),
Sparky
Hi Sparky,
Have you by any chance read the pdf scans of the reviews that I posted earlier inside this thread to backup my position? I'd really appreciate it if you (and everyone else who's knee-jert reaction is simply to discount my assertions as unfounded) would at least take a look at those reviews before posting yet another a response that poo-poos my claim. If you can demonstrate to me exactly how those measurments are flawed, then I will gladly change my position. But so far nobody has...
http://audiokarma.org/forums/showthread.php?t=106298&page=2
Even the mighty skeptic EW was impressed after he read them. Anyway, I will freely admit that even the best Naks could not do it without the aid of Dolby C, and its little known "spectral skewing" feature which increases HF Headroom (without the aid of HX Pro). But when using Dolby C, some of the best Naks could make it a little past 19kHz at a 0dB record level with all tape types. :yes:
goldear said:
Hi Sparky,
HI JIm,
Fair enough to complain that I hadn't read the PDF's. Your'e right. I had not not but I have now. I'm impressed too. As you know, I'm no NAK basher. I was not trying to downgrade their performance. The Dolby C case really is incredible performance on both the BX-300 and the Dragon. I assume that all other Nak three head machines with Dolby C are just as good.
I think we have a happy situation where both of us are right. My original statement was viewing the issue from the point of view of calibrating heads, eq, and bias all of which would be accomplished at -20db on the test bench. All Nak standard calibrration tapes are also recorded at -20db. All standard Nak record/play specifications are quoted at -20db without either Dolby B or C.
You were stating a more performance based case using Dolby C.
So, I applogize for not reading the PDF's which certainly support your case. But I must say that the information in the PDF's are new to me. In Nak's advertising literature I have never seen the Dolby C case at 0db stated. I wonder why that is. Is it because the nature of cassettes does not provide a stable enough media to be able to guarantee that level of performance consistently? I don't know.
I'm going to go pat my Dragon on its head for being such a fine Dolby C machine. BTW, for all you doubters out there, the Dragon definitely sounds just like Jim implies. It's an incredible sounding deck both for Dolby B or C. Personally, I use Dolby B a lot for recording so I can maintain compatability with my other cassette machines. But for tapes intended for use in my main system with my Dragon I always use Dolby C and metal tape.
Sparky
I am an EE. And I only even brought this up point after your spiel about working as a Tech at Teac and all clearly trying to make yourself sound more credible. And then you say that you have only been doing this for a short time. Ok, which is it? Years of working as a Tech on analog recorders, or just a few month of new found interest?
As I said, I am also an EE, but before I was, I worked at TEAC in the early 1980's. I fixed about a thousand machines while working there, but I still would like to know more about the actual design and tape magnetics. I could learn some of that just from experimenting, if I put the time into it. I do have the know-how and test equipment to do the electronic part of that, and I have transports. I'm not about to try to make my own heads, but I can design and build the circuits. Perhaps 1% of my work as an EE over the years has been related to tape recorders, and that was for one of our private-aircraft products in about 1987.
Apparently you did not look at the link I posted from Dolby's own website, specifically page 11 showing the nearly 2:1 compression ratio at 10kHz. I know it's not a linear compression, but a 55dB range is squeezed into 32dB in the 10kHz region. So as you said,
this is essentially what I was saying at the beginning, before I found the explanation on their website-- that you can't get something for nothing. Now I've found out where you pay, ie, where the trade-off is, to get the extended frequency response. So the mystery is solved.
Ok, perhaps we are mostly arguing semantics. I still take issue with your 2:1 characterization, but I can at least now see how you came to this somewhat mistaken conclusion.
You are looking at a 55dB window only. If you look at a wider window, the amount of compression will be less, because the boost never gets greater than a maximum amount. And if you look at a narrower-window, it will also be much less, because the boost will be lessened. And if you look at a narrower window of dynamic range it will also be less, because the boost becomes less. So the amount of compression varies constantly, and so your 2:1 figure might come somewhat close to representing the maximum compression that is achieved over that specific 55dB window. But the average upward comrpession is significantly less on most program material.
By contrast, DBX truly applies 2:1 compression at all levels. DBX's compression is differential in nature, and is not a sliding band of equalization curves that are dependent upon the record levels based upon an absolute reference level, as is Dolby.
And I did not happen to notice anywhere where Dolby specifically characterized thier compression as being 2:1 either. That seems to be your (somewhat mistaken) interpretation of this one graph. But I can now see where you got this idea at least...
But I'm tired of arguing with you. So let's just stop. OK?
Thanks!
I hope there is some great yongun's out there that want a more quality recording than CD-R's which most of you know don't play well after a few yr's
I'd thought I'd bump this post to allow Des Lab to read it. But we all know such a deck will never happen, hence a "dream" deck. To show others what the two good decks that I have now that I'd want to have such a dream deck replace, here they are. An Aiwa XK-S9000 and Sony TC-K909ES. Please dont mind the fingerprints on the Sony. I didn't clean it for the shot.
Aiwa:
http://audiokarma.org/forums/attachment.php?attachmentid=49704&d=1179713199
Sony:
http://audiokarma.org/forums/attachment.php?attachmentid=49705&d=1179713937
Goldear,
Are you able to post some scans from the Audio Magazine with the old Naks in them and the graphs they made? I'd like to see those.
I wonder with the comeback of reel to reel if such a cassette deck would be possible in the future should cassettes make a comeback.
It might happen. There is some concern that digital tape & other digital formats are turning out to be not as reliable as previously thought. That's one of the reasons I started using analog cassettes again.
I read an article where someone at one of the major labels tried to play a digital tape from 1989 & their machines couldn't read the tape. Not only that, but the article said that major studios still use analog 50% of the time at some point during the recording process.
McIntosh has a turntable out with their name on it, think Ivan can talk them into making a cassette deck for us?
Status
