If you bend the spray straw end into a hook shape, you can spray into the large pot openings near where they are soldered (see two arrows top right). Or spray into the two small openings (bottom arrows).
Uh oh! Hole in new brass pulley is too small for shaft. Now what :scratch2:
I'd contact WJOE and have them send you a new pulley with the correct hole-size. Maybe measure the motor shaft size and give that info to them to be sure.
While you are waiting for the new pulley, I would rebuild the reel motor. It is very easy on the CT-F1000 as it is held together with screws. You can follow these steps: http://www.audiokarma.org/forums/showthread.php?t=53981
God AK is such a great place :thmbsp:Sweet Grab there! I've got some Decks on the back burner waiting for a rebuild, a CT-F700, and a CT-F1250. Seeing this makes me want to get mine up & running after years of non-use, although I do have a CT-F8282 unit that was a NOS unit, which is on my rack doing duty now. Fantastic deck, BTW. :thmbsp:
