The more I look at it, the more I realize that the restoration that was performed on my amplifier seems more of a serviced/recapped than the full restoration I had in mind when I had the work performed. Nothing wrong with that as I am still amazed at how good this amplifier sounds. But on the other, I noticed some occasional "friend bacon" noise when I am close to the speakers and the strangest thing is particularly that on female vocals (or when the sound is "full") there is that "SSHHHH" sound that is added like a layer onto the music. Or, if you wish, this sound is like separated from the vocals. It seems to happen on a certain range of frequencies. It is a bit disturbing and I don't know if this is normal with this amp or if a full restoration could fix that.
Knowing this, I think I may be willing to go "phase 2" with this amplifier. I stumbled accross a site called "crossed path vintage" where a CA-1000 was fully restored on their portfolio. They made a complete list of all the work they performed and I would like to use this as a guide to establish the work scope. I would appreciate if you could give your input based on your experience if I should add/remove some parts of the scope.
Note: I contacted them with no luck. Their website doesn't seem to have been updated since 2016...
1- Full Replacement of ALL the electrolytic capacitors throughout the unit. 44+ capacitors.
Okay, my unit has been recapped but I may have to do a caps count and show actual pictures of the items replaced.
2- Full Replacement of ALL the tantalum capacitors throughout the unit. 30+ capacitors.
3- Full Replacement of ALL the outhouse shaped transistors (2SC458, 2SC734, 2SC1124, 2SC1166, 2SC1345, 2SA561, 2SA661, 2SA841) and any others known to get noisy or fail over time. Over 45+ transistors.
Edit:
3.1- Full replacement of all small signal transistors.
4- Replacement of ALL the Main Output Transistors with high-quality ONSemi MJ Series and application of new thermal grease.
5- Replacement of ALL the Variable Resistors to Bourns Multi-turn Trimmer Potentiometers to allow for precise fine tuning and calibration.
6- Replacement of the Main Power Supply Protection Relay.
7- Replacement of the 4 critical Power Supply Ceramic Disc Capacitors.
8- Replacement ALL 8 Protection Fuses.
No issue here. I already changed the main fuse with a Synergistic Quantum Blue fuse, with great success. It is planned that all fuses will be replaced with Blue over time.
9- Full Replacement of all of the Fusible Resistors throughout the unit. 27+ fusible resistors.
10- Replacement of Critical Diodes (both switching and zener) throughout in the amplifier and function boards.
11- Replacement of Both Class A/AB Microswitches with high amperage units that should last forever. The originals get severely tarnished leading to eventual failure and this is a must to upgrade these for long-term reliability.
12- Full disassembly of the power switch and proper cleaning to restore the original luster of the contacts and provide trouble free service.
13- Replacement of the power on indicator light with a color appropriate Warm White LED assembly that provides a bright red power indicator light due to original red filter lens.
The main red light has been changed for a new one since it was burnt out. I don't plan to change it since I am satisfied with the end result.
14- Thoroughly clean all controls, lubricate and properly preserve for long-term protection from noise and static.
15- Precisely complete all of the Service Manual calibrations to be spot on in Both Class A Mode and Class AB Normal Mode.
16- Professional cleaning, detailing and polishing inside and out…
17- Thoroughly clean inside and out as well. Professionally cleaning and properly lubrication of internal controls to ensure excellent long-term performance
18- Professional cleaning of all pots and lubrication as well
19- Verification of all capacitors, transistors and resistors to be in spec (that remain original) and replacement of all the electrolytic and tantalum capacitors and most all of the transistors as stated above.
20- Replacement of the transistors and resistors as needed, replacing any and all stressed parts or parts that are known to problematic over time (like outhouse shaped transistors and fusible resistors.) Use a stricter 5% tolerance when checking parts to ensure a long future for “new” vintage gear. Most specifications allow for a +- 20% discrepancy and; use +- 5%.
21- Check ALL of the solder joints for cold joints, and clean and reflow where necessary.
22- Use of Nichicon High Temp Electrolytic Capacitors (UPW, UKL, etc), Nichicon Muse Capacitors, Elna Silmic II Capacitors, Panasonic Electrolytic and Stacked Film Capacitors and WIMA Stacked Film Capacitors as well as Zetex, OnSemi and Fairchild semiconductors and Xicon 1% metal film resistors when needed. Most consider these the best choices for vintage restorations. Always upgrade the voltage and temperature minimums on capacitors when appropriate to provide even longer service than the originals. All parts sourced from authorized USA distributors to ensure parts are genuine.
23- Edit: Full disassembly, cleaning and lubrication of coupler switch.
Added:
24-Full disassembly , cleaning and lubrication of functionselecor
Added:
25- Cleaning the male/female pins of all connectors on the function board along with those backplane pins from the rca's
Now, I will stress again that I am no tech unlike most of you. Just a hobbyist audiophile looking for the best CA-1000 known to man
so please consider my limited knowledge, and my curiosity.
Cheers,
Serge
