Thanks for your kind words. Tim.
I did check all the ground connections and they all measure 2 ohms. I did try shorting the jacks per Larry and the hum went away as he said it is supposed to.
The hum on AUX went away when I took the blue wires off the t-strip per Dave's post. So now the hum is on PHONO, both inputs, and TAPE HEAD where it's slightly louder than on PHONO. The hum is equally loud in both channels.
I have checked other leads for dual ground and there are several from the input jacks to the selector switch IIRC. I'll check them to verify the connections are good. I don't remember seeing any bad connections and I've been checking those, multiple times with probing all the wires with a plastic alignment tool.
Yes the sound changes when I touch the chassis. But the hum gets only slightly less in volume. I don't believe I tried touching the shield side of the input jacks. I'll try that. What am I looking for and what would it mean?
Remember, I'm doing all these tests with NOTHING connected to the 500-C except dummy 8-ohm, non-inductive loads. No TT, nothing. I've proven the hum has nothing to do with external devices. My LED light, when turned on and off, does affect the hum, but with it off, the hum is still there. When I do connect a TT, the hum doesn't change. Still there, still the same volume.
I'm wondering if maybe the hum is being induced by one of the mods I did. Maybe the mod leads are too long or too close to other parts carrying strong DC current or I used the wrong type of part. I don't remember WHEN the hum started unfortunately.
A new symptom last night - when I touched the top of 2 of the caps on the SDS board, I got quite a shock. Wasn't expecting that. Wondering if that's a clue. Maybe that damn SDS board is causing the hum. I wouldn't mind removing it if I could find instructions on how to rebuild the power section. The cap cans are all made inoperative by the SDS board and I'd hate to have to rebuild those cans. I've done it before though. I'd just buy the Hamfest cans and install them.
I agree with you that it's a ground problem. I've seen it with my guitar rigs. Those issues could usually be fixed by lifting the ground, reversing the plug (they're all 3-way now so that solution is out though some of the effect devices are still 2-way) or trying a different AC outlet. The latter I've tried and it doesn't change the hum.
I spent all last night with a scope and with a MM trying to find a clue. I'm really at a loss for this one. It's kicking my butt.
I'm not giving up though. Soon but not yet. My Marantz 2265B has been a good substitute.
Thorne
